Old 01-23-2013, 03:01 AM
kayak26143 kayak26143 is offline
Vehicle: 1996 ram 1500 4X4
kayak26143 is on a distinguished road
Default Tail lights and license plate lights out help
1996 ram 1500 5.9 4x4 I have checked the fuse, went ahead and replaced the bulbs, turns, backup flashers, and brakes work just dont have any running lights or license plate lights any help would be great as i drive this truck daily and come home at night.... and it has to be -10 outside here in wisconsin the best time to try and fix a truck lol
Old 01-23-2013, 10:53 PM
MACADO MACADO is offline
Vehicle: 2004 Dodge Ram CTD
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft
MACADO is on a distinguished road
Default Tail lights
The '04s have a relay, that controls the tail and lic. plate lights. On that truck it's located, in the main electrical box, under the hood. I don't know if yours has the same set-up, or where the relay could be. If you could get a wiring print, library/ dealer that could get you in the right direction. P.S. You may also have more the 1 fuse. Mine has a 50 amp fuse then the relay then a 10 amp for each tail light. Worth a try....
