Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V10 Specific Topics
Old 01-23-2013, 11:08 AM
whaley1 whaley1 is offline
Vehicle: 1996 dogde ram2500
whaley1 is on a distinguished road
Default 96 dodge 2500 8.0l v-10 won't start
my truck will turn over and has fire and fuel. But will not start. What could be causing the problem??? Thanks
Old 01-23-2013, 03:08 PM
99 V10 99 V10 is offline
Vehicle: 1996 SLT
99 V10 is on a distinguished road
It has fuel to the engine? & spark to the cylinders? Then it should start. Have you checked your fuel pressure? & are all cylinders firing? Have you checked your plugs to see what they look like?
I guess bottom line without standing next to the truck which I'm not, a little more info would possible help.
Old 01-23-2013, 03:13 PM
Rep:1885
Define "has fuel". Depressing the schrader valve and getting a squirt doesn't mean you have adequate pressure or an injector pulse that is needed to get the fuel into the cylinders.
Old 01-24-2013, 12:38 AM
Vehicle: 1996 SLT
I love these kind of questions. Like we are standing there. As stated a big difference from gas in the tank & gas getting in the cylinders.
Old 01-24-2013, 12:50 AM
Yes gas to cylinders, pressure correct to injectors, spark plugs new and all are firing. Now that said. this is why I'm asking the question. Have checked everything that I can think of down to fuses and relays.
Old 01-24-2013, 08:29 AM
Rep:1885
I notice you didn't mention an injector pulse...
