Old 01-23-2013, 04:37 PM
Detroit3000's Avatar
Detroit3000 Detroit3000 is offline
Vehicle: 2009
Trim Level: Big horn
Color: Brilliant Black Crystal Pearlcoat
Rep:68
Detroit3000 will become famous soon enough
Default Ready to order wheels! But need offset help
Back when the economy took a dump I lost my company vehicle. Times have been really good the last 2 years so I got a company ride again! So I'm ready to Order a set of rims for it, but the whole offset things boggles me. I read the charts and still not sure what I need. Truck is a 2012 2500, came from the factory with 33x11.5x17 BFG all terrains. I pulled the stock fender flares and added a set of bush whacker pocket flares which stick out a little farther than the stock ones. I'm looking to but a set of 17x8 ballistic wheels with 35x12.5 but not sure if i need the +12 -12 or 0 offset. I want them to fit like the stock ones do, I don't want them to stick out past the flares.... I thought a + offset sucks the tire in more but with a wider rim and wider tire I don't know... Any help would help!! Thanks......
Old 01-23-2013, 05:37 PM
HoosierHemi's Avatar
HoosierHemi HoosierHemi is offline
Vehicle: 2011 Dodge Ram
Rep:115
HoosierHemi will become famous soon enoughHoosierHemi will become famous soon enough
This diagram might help:
but im still scratching my head why you'd be spending money on a company truck that's not yours...but hey that's cool you get to play around with a nice truck that's not yours either
2011 Black 1500 Sport QuadCab 4x4
Old 01-23-2013, 08:48 PM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
Well I believe your stock wheels are 17x8 with a 0 offset.
So the aftermarket 17x8 w/a 0 offset will fit the same. The two other wheels will stick out 1/2 further or suck in 1/2..The tires will hang 1/2 more over the wheel width on each side.
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Thuren | Carli
Old 01-23-2013, 08:56 PM
Ram725's Avatar
Ram725 Ram725 is offline
Vehicle: 2012 Ram 2500 4x4
Rep:347
run 0 offset. -12 pushes out and +12 sucks it in. 0 offset should be stock.
If I am wrong someone correct me.
Build Thread
SOLD: 2012 Ram 2500 CTD 4x4
Old 01-24-2013, 04:03 PM
oldbluehairhemi's Avatar
oldbluehairhemi oldbluehairhemi is offline
Vehicle: 2008 Dodge Ram 3500 Dually
Trim Level: Laramine
oldbluehairhemi is on a distinguished road
if you put bush wacker pocket flares on and you get wheels with 0 offset IMO it will look out of place. -12 offset will widen the stance of the truck but should not stick out past your flares.
