Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Old 01-23-2013, 11:46 PM
killfordoe's Avatar
killfordoe killfordoe is offline
Vehicle: 2012 Dodge Ram 1500 4WD
killfordoe is on a distinguished road
Default Please delete ---moved----
Hi folks,
I was wondering if anyone could help me out with a question I have about replacing the front drive shaft on my 1996 Dodge Ram 2500 4 wheel drive.. I want to replace the drive shaft ,and my truck currently has a 4-Spd. Automatic 46RE Transmission, a Shift-on-the-Fly, 241 Transfer Case and a Dana M60/248MM Front Axle...I was wondering if there would be a problem putting a reman. drive shaft Trans. code 47RE; with NV241HD Transfer Case; Front; Automatic trans. in the truck. With the only difference being the 46re and 47 re,,I believe it has something to do torque?
Hope I explained this well enough and I thank you for any advice you could give me!!!
Cheers
