Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 01-24-2013, 09:22 AM
dmclemore dmclemore is offline
Vehicle: 1998 Dodge Ram
dmclemore is on a distinguished road
Default Dmc
Headlights went out yesterday.Replaced 40amp fuse under hood.Blows another one,was told it was headlight switch, replaced switch still blowing fuse! Help!!!
Old 01-28-2013, 10:51 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
You've done the easy stuff, now it's gonna be a matter of tracing out the wiring and figuring out where the short it.
You can start a either end... you'll need an ohm meter and a lot of patience. You'll need to unplug your head light bulbs, also unplug it from the head light switch, then do a continuity check from one end to ground... working your way back... This is where a wiring diagram will be helpful.
You can also do a visual inspection of the wires and look for the obvious.
There isn't an easy way to do this... you'll pretty much have to check everything and eliminate things as you rule them out.
good luck
Exco
Bill
Old 03-07-2013, 07:01 PM
crazzywolfie crazzywolfie is offline
Vehicle: 81 91 93 dodge
crazzywolfie is on a distinguished road
did you inspect the plug and wiring at the headlight switch? pretty much every truck pre headlight relays usually eventually have a problem with the headlight switch or wiring to it.
91 & 81 d150 carburated 318's 93 R.C. F.I.318
