Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 01-24-2013, 10:03 PM
Jimeeh1 Jimeeh1 is offline
Vehicle: 2011 Ram
Color: Slate
Jimeeh1 is on a distinguished road
Unhappy Climate Control Not Working
Just had a pleasant six hr ride from Vermont with no heat or ac(defrost). Was initially working this morning in sub zero temps but then just quit. Climate control lights are out and will not switch to warm or divert from floor but blower fan works. Assumed it may be a fuse but didn't find one blown that i would think would be associated as described in owners manual. One other thing I found was the headlights will not work in auto and when switched to this position, the dash headlight indicator goes out.
Any help would be greatly appreciated,
Thanks,
Jim
Old 01-25-2013, 10:02 AM
rdsabin rdsabin is offline
Vehicle: 2012 Sport Reg Cab 4x4
Trim Level: Sport Reg Cab
Color: Mineral Gray Metallic
Rep:186
rdsabin has a spectacular aura aboutrdsabin has a spectacular aura about
The headlight sounds like a problem I had, the dealer ended up replacing the switch. It would not work on auto and if you manually turned the switch it would light up dim when it should be full lighting and off when it should be on. Pain when you have to be on the road at 4:30am. You other issue I can't say anything other than if you are still under warranty get it in and have the dealer deal with it.
2012 DodgeRam 1500 4x4, 20% Tint, Running Boards, Class IV Hitch, 14" Win Muffler, Catch-Can, Tow-Hooks, LED Tailgate Bar
2008 Dodge Supe Bee, Catch Can, Backup Camera, 20% Tint all windows, CAI, AFE Filter
Old 01-26-2013, 10:33 AM
Vehicle: 2011 Ram
Color: Slate
Well, started checking any fuse that may be remotely associated. Started the truck and it was working again. Great. I guess I have a loose connection. Anyone know where I can Get A schematic?
Old 01-26-2013, 11:03 AM
Arth's Avatar
Arth Arth is offline
Color: Deep Cherry Red Crystal Pearlcoat
Rep:2035
A member on here named RamTech can help you out. He is very good at hunting down diagrams and such.
Chrome... in moderation.
Old 01-30-2013, 10:34 PM
Ramzaq Ramzaq is offline
Vehicle: 2009 Ram CC 4X4
Trim Level: SLT, Big Horn
Color: Black Pearl coat
Rep:251
Ramzaq is a jewel in the roughRamzaq is a jewel in the roughRamzaq is a jewel in the rough
This should help with you HVAC system.
For those out of warranty and like to fix your own things, here is a quick guide for that clicking noise.
Chances are it is only the motor that is bad if it is clicking or thumping.
Not very hard to fix really. I think most of these cases are the motor gears stripping and not the doors themselves.
If you know how to take the center stack bezel around the radio off you are halfway there. Don't forget about the screw over the 115V out let. Take the bezel off then the two side 12V acc. plugs. Remove the ring bezel around the cup holder if equipped.
The culprit is the lower center motor, unplug remove two screws and remove.
If the gears are stripped you can position the big gear 180 out from the smaller gear. The door only travels about 120 degrees so won't hit the stripped part.
Reassemble and you should be good to go. 1 to 2 hours of your time. If you want to get a new motor it is about $40 from Chrysler.
Hopefully this is the extent of your problem.
Old 05-21-2013, 08:13 PM
BlownGP's Avatar
BlownGP BlownGP is offline
Vehicle: 2009 RAM CC Sport
Color: Sunburst Orange Pearl
Rep:15
BlownGP is on a distinguished road
I think this is my problem. There is a loud clicking noise coming from behind the dash... And air will only blow on the floor!!!
This sucks
What's the part number for that motor?
98 GTP-Mods? Yeah, lots of them
2009 Ram CC Sport- Mods very SOON!!!
Old 05-21-2013, 08:32 PM
Rep:2705
BlownGP
you may want to check with your dealership
the 2009 Ram had an issue with the Climate Controls
There was a Technical Service Bulletin ( TSB ) put out on it
even though you are out of the 3 year warranty
you may still be covered under that TSB
Automotive Recall and Technical Service Bulletin Titles for 2009 Dodge or Ram Truck RAM 1500 Truck 2WD V8-5.7L.
J12 JUL 09 Recall - HVAC Control Module Programming
K17 SEP 10 Campaign - AC Control Programming/Air Door Actuators
24-004-09 NOV 09 A/C - Hissing Noise With A/C ON
also click the line that begins with
I NEED RECALL ......
http://www.dodge.com/webselfservice/dodge/index.jsp
last but not least, here is more info
http://www.ramforumz.com/showthread.php?t=41144
Old 05-21-2013, 11:13 PM
BlownGP's Avatar
Rep:15
BlownGP
Oh wow.. Thanks for that link.
Yup. The a/c reprogram hasn't been done. Then sure sounds like more than a reprogram. They better change the actuator if its the problem too.
Old 05-25-2013, 02:22 PM
BlownGP's Avatar
Rep:15
Well, that was the problem. Needed to be reprogrammed. Thank god becasue I am taking a road trip this weekend.
Old 10-21-2014, 06:42 PM
rfd52fire rfd52fire is offline
Vehicle: 2011 Ram 1500
rfd52fire is on a distinguished road
Thanks,
Jim
I am having the exact same set of symptoms in my 2011. It started with the HVAC controls not switching off floor and then last night my headlights would not come on in "auto" mode and the lights behind the HVAC controls will not light up and the only air I am getting is ambient from outside (blower still works). Did you get this solved/were you able to figure it out? From what I have read the best I can figure is that is some kind of computer or module issue and it will need to be flashed/reprogrammed. Thanks for any help.
