Dipping RPMs and sporadic temp. gauge? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-24-2013, 11:51 PM
RamtasticVoyage's Avatar
RamtasticVoyage RamtasticVoyage is offline
Vehicle: 1997 Dodge Ram 1500
Color: Blue/Silver
RamtasticVoyage is on a distinguished road
Default Dipping RPMs and sporadic temp. gauge?
Since no one responded to my other post, I'll try again, with a shorter description. Just the other day, my truck started to act funny. When the engine temp. is still cold-ish (halfway between running temp. and full cold), the RPMs dip down when I'm at a complete stop, like it wants to die, but doesn't. If it's in PARK, it doesn't do it so much. I also noticed my temp. gauge is all over the place at times. Not sure why it's doing this.
Any ideas?
1997 Dodge Ram 1500; Extended Cab Laramie; 5.9L 360ci V8 Magnum
Old 01-25-2013, 09:48 AM
Resident Technician
Rep:1915
Start with the obvious. Check your coolant level and condition. The erratic idle could be from a dirty throttle body and/or blown plenum pan gasket, so check for that first.
Old 01-29-2013, 05:02 AM
Color: Blue/Silver
Everything seems to be running fine now. No chugging and sporadic temp. gauge. I think the battery being totally drained maybe messed with some of the computer learned codes. Either that or it was the nasty cold snap we had for a couple of weeks that messed with it also. Thanks for the response!
