Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Powertrain > 5.7L (345 cu in) HEMI V8 Specific Topics
Old 01-26-2013, 02:44 AM
levidunlap levidunlap is offline
Vehicle: 2011 Dodge Ram 1500
levidunlap is on a distinguished road
Default 2011 ram CEL P000B
Ive got my 2011 ram with the 5.7 hemi. Well as I was driving home today my CEL came on. So i reset the battery just so I could clear it to see if it were to come on and boom soon as I start driving it comes back on. Well finally when I got home I did the mopar trick where you cycle the key 3 times and the code P000B shows up but I have no idea what its for. Any ideas?
Old 01-26-2013, 03:11 AM
Rep:2657
what you thought was a B, is an 8
P0008 Engine Pos Sys Perf Bank1
that is what comes up, what it means i have no idea
Old 03-10-2013, 03:57 PM
Prochargedram's Avatar
Prochargedram Prochargedram is offline
Vehicle: 2010 Dodge Ram R/T 1500
Trim Level: R/T 5.7Hemi
Color: Blue
Prochargedram is on a distinguished road
Engine Position System Performance
What does this mean?
OBD Code P0008refers to
Engine Positions System Performance Bank 1 is the generic definition for the P0008; however your vehicle's manufacturer may have a different definition for the P0008 code.
Symptoms
Possible sumptoms of OBD code P0008
- Engine Light ON (or Service Engine Soon Warning Light)
Causes
Possible causes of OBD code P0008
This error basically means the engine is out of Sync. Stop using the vehicle without delay! The Camshaft and Crankshaft are out of position or at the very least think they are. Engine timing may be out and thus your engine is in danger of complete destruction. At the very least a camshaft sensor maybe down.
Old 05-24-2013, 09:44 PM
glen1955 glen1955 is offline
Vehicle: 2011 Ram Crew Cab
Color: Dark Brown
glen1955 is on a distinguished road
I find it very hard to believe that no one has shared what P0008 code is. I've read numerous pages with the same explanation that makes no sense. The engine isn't going to self destruct. Thing I have experienced is- the oil change light came on 3 days later the P0008 code and the little engine light came on, the cruise control stopped working and the ECO stopped working and gas mileage dropped. I've changed the oil tot he specified 5w 20, going to change plugs soon. If you know what is causing this code share it.
Old 05-31-2013, 09:20 PM
Color: Dark Brown
Changed plugs and cleaned throttle body today, cranked engine afterwards, ran rough for a few minutes and the smoothed out. Checked codes and had P0008 and P0016 with the engine light on. rechecked codes and they were gone but engine light blinks 10 times. Engine runs smooth. Anyone have any ideas what is going on?
Old 05-31-2013, 09:42 PM
Rep:2657
The P0008 DTC code is generic, so that means it applies to all makes of vehicles. This source says it best:
The Engine Control Module (ECM) tests for misalignment between both camshafts on one bank of the engine & the crankshaft. The misalignment would be at an idler sprocket for either bank or at the crankshaft. Once the ECM learns the position of both camshafts on one bank of the engine, the ECM compares the learned values to a reference value. The ECM will set a DTC if both learned values for one bank of the engine are exceeding a calibrated threshold in the same direction.
Symptoms of a P0008 DTC may include:
•MIL (Malfunction indicator lamp) illumination
•Roughness while accelerating
•Poor fuel economy
•Decreased power
•Timing chain "noise"
Potential Causes
Potential causes of a P0008 code may include:
•Stretched timing chain
•Crankshaft reluctor wheel has moved and is no longer referenced to top dead center (TDC)
•Timing chain tensioner problem
Possible Solutions
If your vehicle is new enough that it still has powertrain warranty left, by all means let the dealer perform the fix. Generally, diagnosing and fixing this DTC will involve inspecting the timing chains and tensioners for excessive wear or misalignment, and inspecting the crank reluctor wheel for proper positioning. Then replacing parts as required.
General Motors has really had vehicle issues with this code, be glad that you don't own one
Old 06-24-2013, 08:54 PM
Color: Dark Brown
After changing oil, plugs, cleaning throttle body, and running sea foam, all codes cleared and vehicle returned to it normal self. My opinion is oil change light on and oil was with dirty for about 1000 miles causing P0008 code and other issues. Have driven the truck for about 1500 miles and is normal. Change the oil and clean throttle body at the same time it'll prevent issues and keep it running correctly for a lomg time.
cel, check engine light
