Old 01-27-2013, 02:08 PM
MoToCroSs986 MoToCroSs986 is offline
Vehicle: 2012 Dodge Ram 1500
MoToCroSs986 is on a distinguished road
Default Alpine Head Unit IVE-W530 does not fit 2012 Ram 1500
As per title, the IVE-W530 does NOT fit in place of the stock radio. The tight dimensions of the stock radio are as follows:
Width 7 3/16 inches
Height 3 1/2 inches
Depth 5 3/4 inches
Old 01-28-2013, 10:52 AM
11Express's Avatar
11Express 11Express is offline
Vehicle: 2014 Ram 2500 Big Horn
Rep:21
11Express is on a distinguished road
I recently installed an Alpine IVE-W535HD in my 2012 Quad Cab. I did have to do some trimming, like others have had to do when installing aftermarket double din units, but it does fit.
Old 01-29-2013, 10:18 PM
audio ram audio ram is offline
Vehicle: 2012 ram sport crew
Trim Level: sport
audio ram is on a distinguished road
I have done several alpine double dins in new rams at the shop. You need to trim a little out in the dash
Old 01-29-2013, 11:06 PM
Well that sucks. I had the stock radio out. Do you only have to trim the plastic or do you also have to trim the metal rectangle behind the plastic as well.
Old 01-30-2013, 01:59 AM
Trim Level: sport
Just the plastic from what i remember
Old 01-30-2013, 02:55 AM
Rep:2616
double din bezels for newer Rams 2009 & newer
https://sites.google.com/site/tricke...9-11-dodge-ram
I believe there is a area behind the bezel that also needs some trimming, using a dremel or even a straight blade saw
Old 01-30-2013, 10:18 AM
11Express's Avatar
Rep:21
I had to trim a bit of the plastic and then also the top part of the metal. I used a small hack saw to cut the metal, it is pretty thin and was easy to cut, just not a lot of room.
