Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
tonneaucovered.com
Old 01-27-2013, 04:52 PM
buzzvoodoo buzzvoodoo is offline
Vehicle: 2002 quad cab 4.7L
Trim Level: Quad cab
Color: yellow
Rep:13
buzzvoodoo is on a distinguished road
Default Oil Cap Yellow / white sluge normal?
I was checking my trucks fluid levels today and took off the engine OIL cap. LOTS OF YELLOW froth build up on the cap. I called my friend who owns his own repair shop (40+ years car repair) and he informed me that it is normal on the 4.7L engines because moisture gets into the cap area / PCV system and develops on the cap.
I called up a 2nd friend who is ASC certified and he said not to worry about it as well because moisture in this cold weather gets into the system and builds up as yellow / white residue. He told me that if you check most trucks out on the road right now you will most likely see the same reside build up.
I was curious if anyone else has noticed this build up on their oil cap. If not can you guys please help a member out and check your oil caps and report back with the findings?
INFO
29 deg F temperature outside.
139K miles 4.7L bone stock.
Oil on the check engine dip stick looks normal.
Old 01-27-2013, 05:17 PM
Rep:2737
It is normal on the inside of that cap
shine a light down in the engine, i doubt if you will see the same moisture build up
many moons ago, motor oil was refined differently, & you could not use one brand at one oil change, then a different brand the next time,
Some were not compatible & would cause a similar build up on top of the heads
Ram 1500 SLT Quad cab, 5.7 HEMI(R) , 3.55 differential, EGR bug deflector, Bushwacker fender flares, custom soft tonneau, Line_X, DEBO Step, Mag-Hytec
2016 Ram 3.0 diesel undergoing Mods G2 tonneau, Line-X, Weathertech mats, Mag-Hytec differential cover, , customized Nfab bars, CB radio, Autonet wi-fi router
Old 01-27-2013, 05:21 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
I have not personally experienced this, however I have read about it a few times, and I called my service manager at the dealership I work with and he too said that it is normal and not to worry
Thanks
Jeremiah
Discount Auto Performance
sales@revelperformance.com
Old 01-27-2013, 06:18 PM
emjohn4 emjohn4 is offline
Vehicle: '12 Ram Sport CC / '02 Durango
Rep:154
emjohn4 has a spectacular aura aboutemjohn4 has a spectacular aura about
Yup, normal.
There is even a TSB out there for re-routing the PCV hoses to reduce it.
Old 01-27-2013, 07:27 PM
HemiLonestar's Avatar
Rep:280
Yup, even the 3.7 and 5.7 we have gets it up there. If you still have the funny looking contraption inside your oil fill, that's why it's there. There was a TSB to put those in to kind of hide it from the consumer.
"Big Red"
2003 Ram 1500 QC Hemi Lonestar "Big Red" (Mods list in profile)
2006 Charger R/T "Little Red"
Old 01-27-2013, 07:35 PM
Archaea's Avatar
Archaea Archaea is offline
Vehicle: 2002 Dodge Ram 1500
Archaea is on a distinguished road
Hello, Buzzvoodoo. Welcome to the club. I remember when I first saw this a few years ago on my own 4.7. I nearly freaked out thinking I was about to blow a head gasket or something.
But no problem. I see it every winter.
Take care-
Archaea.
2002 Dodge RAM 1500, 4.7, 2wd, Quadcab SLT, 100% Original Equipment.
Old 01-27-2013, 09:02 PM
Thetolleyman Thetolleyman is offline
Vehicle: 2003 Ram 1500 Quad Cab
Color: Gold/Silver
Thetolleyman is on a distinguished road
I second that, I freaked too!
[03' Ram, K&N FIPK, Electric fan conversion, Fast Man TB, Superchips tuner, Magnaflow cat-back, 08' intake, 1" body lift, 1.5" coil spacers, 3" lift spindles, 1 1/2" block on rear, rear leaf flip,. [/SIZE]
Old 01-27-2013, 10:13 PM
llrecon llrecon is offline
Vehicle: 2002 dodge ram
Trim Level: sport
Color: red
llrecon is on a distinguished road
I pulled the filler tube off and wrapped it with insulating tape, foil tape and filled the cap with insulating spray foam. Saw a thread on it somewhere and it worked great. Reduced the build up by 95%
Old 01-28-2013, 10:06 AM
Color: yellow
Rep:13
I pulled the oil filler cap off and looked inside of the filler port. I cant see more then 2 inches because this ODD black plastic contraption that is slanted to one side is blocking my view. What is the purpose of this little plastic thing? I am guessing they put it in there to prevent the yellow sludge from dripping down. I got a little lost when you mentioned about Hideing it from the consumer. How does this hide it? I still see a tone of yellow and white even with the TSB plastic contraption shoved in my oil filler cap.
Old 01-28-2013, 10:12 AM
Color: yellow
Rep:13
By the way thanks buys. I almost had a heart attack when I saw this. I might also add its never a good idea to start poking around in the engine bay with the car running. ( running to checking transmission fluid ) you can always nick your middle finger on the radiator fan even with the fan shroud housing covering it. I got lucky it didn't take my finger off. I sawsomething odd that caught my attention.
