Old 01-27-2013, 08:53 PM
Rep:2657
my '09 quad cab with the full center console, close to the shifter the outlet is only on with the key
the one in my upper seat console is always hot
i don't know about the one at the very back of the console, it is only handy for rear seat passengers
Old 01-27-2013, 10:39 PM
Edokdyshi's Avatar
Edokdyshi Edokdyshi is offline
Vehicle: 2012 Ram 1500
Rep:143
Edokdyshi will become famous soon enoughEdokdyshi will become famous soon enough
There are 3 power outlets in my '12 Sport, in center console, top part of storage area, and back of center console. the only one that is hot always is the one in the top part of the storage area. The other 2 only turn on with the key.
18" Magnaflow muffler, 5% tint all around, multiple blacked out parts, de-badged, Westin Bull Bar, K.C. Long Range SlimLites
Old 01-27-2013, 11:32 PM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:71
topgun will become famous soon enough
Originally Posted by BCRAM View Post
On my 1500 QC, the 12v power outlet at the shifter is only hot when the key (fob) is ON/RUN or in the ACC position.
The 12v outlet under the lid of the center console is always hot...meaning even when the key (fob) is not present.
My 2012 2500 Crew with floor console works the same. Pretty sure the one on the back of the console is switched. An easy way to tell how it is supposed to work is by the label on the outlet cover. The switched outlets show a key. Hot all the time will have a picture of a battery.
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Cooper AT3 285/70/R17's, S&B Intake, Moroso Catch Can
Old 01-28-2013, 09:38 AM
rdsabin rdsabin is offline
Vehicle: 2012 Sport Reg Cab 4x4
Trim Level: Sport Reg Cab
Color: Mineral Gray Metallic
Rep:186
rdsabin has a spectacular aura aboutrdsabin has a spectacular aura about
This is from the 2012 OM:
ELECTRICAL POWER OUTLETS
The auxiliary 12 Volt (13 Amp) power outlets can provide
power for in-cab accessories designed for use with the
standard “cigar lighter” plug. The 12 Volt power outlets
have a cap attached to the outlet indicating “12V DC”,
together with either a key symbol or a battery symbol.
A key symbol indicates that the key must be in the
ON/RUN or ACC positions for the outlet to provide
power. The battery symbol indicates that the outlet is
connected to the battery, and can provide power at all
times.
NOTE: To ensure proper operation a MOPAR knob
and element must be used.
So as you can see Dodge designed your outlets to work the way they are. I am sure it is to prevent you from forgetting to unplug an item and running your battery down.
2012 DodgeRam 1500 4x4, 20% Tint, Running Boards, Class IV Hitch, 14" Win Muffler, Catch-Can, Tow-Hooks, LED Tailgate Bar
2008 Dodge Supe Bee, Catch Can, Backup Camera, 20% Tint all windows, CAI, AFE Filter
Old 01-28-2013, 05:47 PM
kaos2be kaos2be is offline
Vehicle: 2012 Dodge Ram 2500
Trim Level: Mega Cab
kaos2be is on a distinguished road
Thanx for the replies, its a 1500 laramie long horn. The power outlet, its the one on the center console just to the right of the shifter. There is a little pocket just to the right of the shifter that the outlet sits in. I think there was a cigerette light in the outlet when I purchased the truck. Anyone else have this same issue? Once again thanks for the replies.
Old 01-28-2013, 06:40 PM
Rep:2657
I remember reading somewhere that using the switch powered front power receptacle/cigarette lighter socket for extended periods of time, or when trying to recharge something like a camera battery, can quickly blow the fuse in that receptacle
On the other hand, the receptacle in the arm rest console is always hot & can be used for extended periods of time with no damage
as a side note:
When i purchase a product like a Garmin NUVI, i also make sure that i also have a charger for the cigarette lighter & a 115 volt charger. The cigarette lighter receptacle seems to be a quicker charger
Old 01-29-2013, 01:42 AM
Black Diamond 357's Avatar
Black Diamond 357 Black Diamond 357 is offline
Vehicle: 2012 Ram 1500 Laramie Longhorn
Trim Level: Laramie Longhorn
Color: Black Diamond
Rep:25
Black Diamond 357 is on a distinguished road
Even if my truck is running my outlet does not work until I push the button to activate it.
Old 01-29-2013, 04:32 AM
pdrules pdrules is offline
Vehicle: 2012 sport quad
Color: deep cherry red
Rep:-11
pdrules can only hope to improve
u guys are all confused some talkin the 12v dc ports some talkin the 110v ac port 2 different deals....i never tried the ac port yet someday ill find a purpose for that always nice to have options...my dads ford doesnt have it
Old 01-29-2013, 12:30 PM
Designflaw's Avatar
Designflaw Designflaw is offline
Vehicle: 2013 Ram 1500 4x4 Sport
Rep:40
Designflaw is on a distinguished road
The one in the pocket next to the Shifter is "Keyed" per the symbol on it and most of the correct conversation here. My problem is, I do not have one in the armrest up storage. There is a round lid like an outlet, but it is a USB.
So I can't find one that stays on either -
2013 CC Sport 4x4: 3.55, 20% Tint, Line-X, fender flares, mud flaps, Weather Techs, bed cover, 2.5 Leveling kit, Blacked out emblems, Vararam Air Grabber
2008 M109R LE, 1999 TL1000R, 2003 Yamaha Golf Cart :hah:
Old 01-29-2013, 05:48 PM
Thanks for all the replies. I finally found the power outlet. It is located in the center console under the arm rest. There are two storage areas. There is a thin storage area directly under the arm rest and a larger storage are on the bottom. The power outlet is located in the thin or smaller storage area. It is on the front right side of the storage. There is a battery symbol on cover. Thanks again for all the replies and help. I greatly appreciate it. Thanks again!
