Old 01-27-2013, 08:57 PM
steveschaedel's Avatar
steveschaedel steveschaedel is offline
Vehicle: 2012 Power Wagon
Rep:61
steveschaedel will become famous soon enough
Default Detector hard wire to uconnect mirror
OK - I will try this again - I dont do this often so hopefullt I can figure it out.
I mentioned in my earlier post but as I tried to insert an image I lost everything so I am starting over again. I looked for this info all over the web and finally came up with enough to try to do this install - not that its difficult but I didnt want to fry my detector or screw up my rear view mirror. I also heard that the wiring colors MAY be different but this worked for me - I cant take any responsibility if this doesnt work for you or damages anything. I am installing a Blendmount from Escort on the 9500ix detector and the kit comes with the pre-pigtailed hardwire attachment.
The first thing you have to do is remove the mirror from the mount so you have room to work with and dont pull the mnount off the windshield.
Now you have to remove the connector on the backside of the mirror - mine was tight so I used some needle nose on one side and pressed the clip inward and wiggled it free.
The 12v switched power wire is the Pink with Lime Green stripe - the ground is the black with green stripe. Again, I read that these may change ocassionally but I thing Dodge would use common wiring colors for common items. The Blendmount kit suggest sliding the ends of the pigtails into the connector with the positive and neg but I couldnt get it to work so I decided to buy some inline splices for the install.
Make sure you splice all the way to the connector so they will fit in the backside of the mirror. I did slide the wiring cover up and remove the factory electrical tape so I had room to work with. After attaching the splices test the detector to make sure it works - remember its a switched outlet so will have to turn the ignition on.
Tape everything back up and install the connector bacck into the mirror and hang the mirror. Should look something like this...
The one thing I didnt like about the Blendmount is that there is no horizontal adjustment and my mirror has two pivot points which means the stem is not perpendicular - I could adjust the mirrir to use and the detector was slightly facing to the right of the vehicle - this pic is what it looks like from point of view out the rearview mirror...
I didnt like it so I used the sticky back rubber in the blendmount kit - cut it half long ways and stuck them together as a shim on the passenger side of the lower part of the blend mount. I know this pic didnt turn out well.
Here is the installed mount and detector
I hope this helps somebody and please let me know if you have any questions.
Old 01-27-2013, 09:12 PM
Rep:2625
welcome to this forumZ
very nice write up, i am sure it will help some people
Old 01-27-2013, 09:41 PM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:83
Turbovsix will become famous soon enough
Great write-up. Been considering this setup for a while so this was very helpful and informative.
Reps as well.
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI - all stock!
2012 Jeep Grand Cherokee Limited
Old 01-27-2013, 09:45 PM
viperr817's Avatar
viperr817 viperr817 is offline
Vehicle: 2012 ram
Rep:195
viperr817 has a spectacular aura aboutviperr817 has a spectacular aura about
Do u have a link as to where to buy the mount?
Old 01-28-2013, 09:09 PM
Rep:61
https://www.escortradar.com/escort-blendmounts/
This is direct from Escort - I think it was $89.95 (yeah its pricey for what it is) you can get them for $10.00 less on Ebay or Amazon but MOST of those DONT come with the hard wire - Escort sells the kit all together. You also want to make sure you get the mount for the recessed stem if its the Uconnect mirror.
Old 01-30-2013, 02:33 PM
xsdbs xsdbs is offline
Vehicle: green flying carpet
Trim Level: upper and lower
Rep:73
xsdbs will become famous soon enough
This is a nice write up, however as an electrical tech I wouldn't be using Scotchloks. Yes, it may work but they are not the best idea. Stripping and soldering or the use of insulated butt splice would be the best choice. Scotchloks tend to loosen up or damage the integrity of the wire.
Just personal preference after doing many repairs because of scotchlok usage.
Old 01-30-2013, 03:06 PM
Rep:1877
I completely agree. I wouldn't use them unless necessity dictated.
Old 01-30-2013, 03:29 PM
viperr817's Avatar
Vehicle: 2012 ram
Rep:195
This post encouraged me to machine up a bracket today. Will see if it works put when i get home and i post some pics.
Old 01-30-2013, 06:09 PM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
So I can use this power wire for my phone?
SPONSORED BY
BULLY'S PERFORMANCE
Old 01-30-2013, 07:21 PM
illucid illucid is offline
Vehicle: 2012 Ram 1500 Sport 4x4 Hemi
Trim Level: Loaded Sport
Color: True Blue Pearlcoat
illucid is on a distinguished road
Nice mod and write up. Did u evere have your 9500 plugged into your cigarette lighter outlet and if so, did it activate laser band when you stomp on the pedal? And if so, does it do that now hardwired into the mirror? I have the same radar detector and this could be a fix for my problem...
