Old 01-28-2013, 04:02 PM
attaboy attaboy is offline
attaboy is on a distinguished road
Default 2010 Ram Overhead Console Wiring
I'm looking to put in an overhead console on my 2010 Ram 1500. The truck didn't come from the factory with an overhead consol but I'm hoping that the wiring harness for an overhead console is there anyway. Does anyone know?
Thanks
Old 01-28-2013, 06:01 PM
APSTRAM's Avatar
APSTRAM APSTRAM is online now
Vehicle: 2012 Ram 2500 Crew Cab 4x4
Color: Deep Cherry Red
Rep:85
APSTRAM will become famous soon enough
No, the headliners for ST trucks does not have the wiring harness that you need. If you are looking to buy a consloe from a salvage yard ask them to supply you with the mounting bracket and the wiring harness.
The plug for the harness is behind a access cover on the left side of your dash visible when you have the drivers door open.
Old 01-28-2013, 06:34 PM
Darn. I was hoping....
I've already ordered the console cover via online but not the bracket piece as yet. I can get the shorter wiring harness from the local dealer for not much of a cost. Is there another harness to the dash connector?
I still haven't found a 2010 service manual so I don't know which pins on the dash connector to connect to. I may have to bypass the dash connector completly and wire directly into the door(s) feed to the dome light and then power the switchs for the lamps directly from 12v source (I'll fuse that line). Do you know where I can get the schematic information that I will need?
Thanks
Old 01-28-2013, 07:54 PM
dwanton's Avatar
dwanton dwanton is online now
Vehicle: 2013 power wagon 2500 loaded
Trim Level: crew cab loaded
Rep:80
dwanton will become famous soon enough
any pics of what the overhead console looks like ? thanks
2013 power wagon 2500 - 5.7 everything but leather.
Old 01-29-2013, 12:19 AM
I got these off an ebay site
Old 01-29-2013, 06:06 PM
APSTRAM's Avatar
Rep:85
You need the mounting bracket but is is available for purchase from Mopar. The wiring harness is not too difficult for you to make. There have been other posts on the subject.
One option you have since you do have the homelink module is to hook up the wire for the lin bus communication if you have or are planning to add the EVIC screen. That wire is also found in the connector under the cover on the left side of the dash. The home link will work just fine if you decide not to hook up the wire you just won't see the display on the EVIC when you are programming.
Look for the 2010 Ram Body Builders Guide in the internet and look at the wiring diagrams for the 3500 chasis cab they have much of the same wiring in the interior and you will see the wiring for the overhead console there.
Old 01-30-2013, 07:07 PM
Default overhead console wiring
Can anyone provide me with a photo of the C1 connector? I've looked under the dash, behind the access cover and I don't see that particular connector. What color is it? Where the devil is that little bugger?
Old 01-30-2013, 07:58 PM
APSTRAM's Avatar
Rep:85
The green one under the side cover is for the power to the overhead light. C1 is the connector to the instrument cluster.
Old 01-30-2013, 09:32 PM
Default Plug location
That's really odd. I don't have a side cover that is removable. Or at least it doesn't look like it is removable. How is it accessed?
attaboy
Old 02-02-2013, 10:28 AM
APSTRAM's Avatar
Rep:85
The edge is almost not visible the way the parts come togeather but they do come apart. I use a very small screw driver to start the cover moving then I can just grab with my fingers and remove the cover.
