Old 03-06-2013, 06:41 PM
I push the skinny pedal
Rep:3277
Originally Posted by FrostKing View Post
Once you go boost you can switch back to a stock throttle body and sell the larger one to get some money back. It won't be the restriction any more.
I know the boost will just push it through irregardless of any restrictions, but I'm curious to see what the pressure differential will be before and after the TB. Mostly I just want to satisfy my curiosity. The end result will be the same, I'm just curious about the efficiency.
Kurtis
Old 03-07-2013, 08:41 AM
FrostKing's Avatar
FrostKing FrostKing is offline
Vehicle: 2003 Dodge Ram
Color: Graphite
Rep:21
FrostKing is on a distinguished road
I suppose with a supercharger there may be a small pressure drop across the TB. That would be an interesting test to try out. Turbo boost pressure is regulated off the intake manifold so it would compensate for for any restriction. When you do decide to hit the dyno let us know. I'm sure a few of us would go to hang out and I haven't seen Davenport's new shop yet.
2014 White Crew Sport 4x4 8-speed 3.92 gear
Sold: 2003 RCSB 2WD
6.4L Hemi - Turbocharged, Alcohol, Nitrous
Old 03-09-2013, 09:05 AM
catsltd catsltd is offline
Vehicle: 2010 RCLB SLT 1500 Ram
Color: Mineral Gray
Rep:72
catsltd will become famous soon enough
I think its only about $160:00 for 2 pulls,which is a great price,maybe you should get your truck done also.
I plan on doing another pull,once I get a custom tune installed this spring before heading off to Mission Raceway.
2014-True Blue SLT,CC 6.4 BOX.
Air suspension,Rambox,Navigation.Backup camera.
3:92 gears.
Old 04-10-2013, 09:44 PM
bgramling bgramling is offline
Vehicle: 2012 Ram Hemi
bgramling is on a distinguished road
ok, so after reading this im still clueless on what throttle body to buy. i have a 2012 Single cab 5.7L and i have a CAI so far but my next thing is throttle body and bbk shorty headers. what size throttle body should i run??
Old 04-10-2013, 09:54 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
Go for the 87. It's what I have. I have intake and headers.
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 04-10-2013, 10:02 PM
What outlaw said. Because you are doing headers I agree and go 87mm.
If no headers, 85mm is what I'd recommend.
We carry TBs as well.
Let me know.
Outlaw, I haven't forgotten you
Old 04-10-2013, 10:14 PM
ironchef2011's Avatar
ironchef2011 ironchef2011 is offline
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
ironchef2011 will become famous soon enoughironchef2011 will become famous soon enough
According to Moe's, it's an 85mm for all bolt ons including headers. Forced induction is for the 87mm and higher.
2012 R/T 392
Old 04-10-2013, 10:16 PM
Outlaw's Avatar
Color: Bright white
Rep:435
Go 87 anyway. I did. Butt dyno likes it.
[/CENTER]
Old 04-10-2013, 11:00 PM
This is somewhat correct BUT if running headers you'll want 87mm
Let me tell you why.
The extra airflow from the 87mm will help if you can get that air out just as easily which is where the headers come into the equation.
But even without headers you'll notice the difference from 85mm to 87mm
Old 04-10-2013, 11:30 PM
Rep:3277
You need to separate boosted and naturally aspirated. Boosted will still function just fine with a stock throttle body. You need to start looking at larger throttle bodies when you start moving larger volumes of air. The throttle bodies that dap and moe's sell are ported with stock butterflies, so all you are doing is creating a smoother transition of the air to increase velocity, not flowing more volume. I would look at going to an 87mm with headers and full bolt ons because you want to flow as much air at higher velocity to clear the combustion chamber as quickly as possible.
Anything beyond bolt ons on a naturally aspirated motor should have a larger true bore throttle body, and any good engine builder will tell you that.
Kurtis
