tonneaucovered.com
Old 02-01-2013, 02:12 PM
Coastline's Avatar
Coastline Coastline is offline
Vehicle: 2013 Ram 1500 4X4
Trim Level: Laramie Longhorn
Rep:15
Coastline is on a distinguished road
I'm pretty sure they are mounted to the frame.
Old 02-02-2013, 03:56 PM
Big Horn 43537 Big Horn 43537 is offline
Vehicle: 2013 Big Horn 4x4
Color: Mineral Gray
Big Horn 43537 is on a distinguished road
Originally Posted by xmanofsteel View Post
They're only attached to the body and not the frame? How solid are they? Could they hold over 300 lbs without bending anything?
Correct, body mount only with 12 bolts. No brackets attach to the frame. I'm 195lbs and I can feel them move a little when I place both feet on the step at the same time.
Old 02-02-2013, 08:19 PM
xmanofsteel xmanofsteel is offline
Vehicle: Looking at 2013 Ram 1500
xmanofsteel is on a distinguished road
That doesn't sound too great for me...lol
Old 02-03-2013, 12:12 AM
pwrman pwrman is offline
Vehicle: 2008 1500
Color: Blue
Rep:12
pwrman is on a distinguished road
A better option is the AMP Research retractable boards. They are $$$ but they are VERY well made. They fold completely up under the body and are invisible until you open the door. My 84 year old mom can step right in now and I am 260 lbs, they do not flex. They are extruded aluminum with a non skid coating. The install was a breeze, the directions were very clear. Best $1k you will ever spend. I have yet to see a set of nerf bar steps that are not rusted through in a few years. Road salt is a bitch.
Old 02-03-2013, 02:07 AM
HorseMan's Avatar
HorseMan HorseMan is offline
Trim Level: Longhorn Crew 4x4
Rep:139
How do you wire up the retractable version? If they slide out when door is open, wiring is obviously required...is it plug and play?
Old 02-03-2013, 02:10 AM
Cookie Monster Cookie Monster is offline
Vehicle: 13 1500 Laramie Crew 6'4
Trim Level: Laramie 8Speed 4x4
Color: True Pearl Blue
Rep:71
Cookie Monster will become famous soon enough
Those are really nice and I may add them later on as the do run around 1-2k for a set. they are really sweet. so till then I will be ordering the wheel to wheel.
Old 02-05-2013, 10:16 AM
crusher's Avatar
crusher crusher is offline
Vehicle: 2014 ram sport crewcab rambox
Rep:368
crusher is just really nicecrusher is just really nicecrusher is just really nicecrusher is just really nice
when i install mine, the mopar version, they bolt/rivet to the fram, no movement, not loose at all, it still solid after 3 years,...
But i did install it with a air impact, i guess if someone would install them with regular ratchet without torquing them enough it might become loose after a while because the more you torque the rivet bolt, the more it become bigger in the hole, it not like a regular bolt,..
my truck is a 2009 but i really dought the install is different on a 2013,.
2014 ram sport crew cab with ram box,side steps,sport hood,remote starter,8 speed &3.92 gear lsd,4 corner air susp,knn intake,mufflex 18, BT catchcan,bakflip F1 cover
Old 02-05-2013, 05:44 PM
Copperhead Ram Copperhead Ram is offline
Vehicle: RAM
Rep:33
Copperhead Ram is on a distinguished road
My sales guy put my order in on the 2nd of this month, but now the wheel-to-wheel side steps aren't available for regular cabs... not sure when it'll be back on dealer connect as a regular cab option.
Old 02-05-2013, 06:29 PM
RogerMedic71 RogerMedic71 is offline
Vehicle: 2012 Ram 2500
Color: True Blue Pearl
Rep:13
RogerMedic71 is on a distinguished road
I have them on my 2500. Im your size and use them to get in the truck. They seem solid enough for me.
Old 02-05-2013, 06:36 PM
Ctrl-z Ctrl-z is offline
Vehicle: 2000 GMC 2500
Rep:16
Ctrl-z is on a distinguished road
Thanks for confirming that. I might have been tempted had they attached to the frame but absolutely will not entertain the thought of body mounted side steps. There's a pretty informative thread here http://www.ramforumz.com/showthread.php?t=125965 about what can happen if those body mounts start pulling out.
I hope that the air suspension park mode will largely compensate for a lack of side steps. With my present truck I had to remove them because of problems getting stuck in deep mud and snow where they become giant floats and don't allow the tires to dig in.
