Old 01-29-2013, 01:19 AM
redhemi06's Avatar
redhemi06 redhemi06 is offline
Vehicle: 2006 Dodge Ram
Rep:36
redhemi06 is on a distinguished road
Default neutral safety switch and starter
http://www.ramforumz.com/showthread....425#post997425
posted in electrical but looks like not many people answer back there
Old 01-29-2013, 09:27 AM
Rep:1909
The only way this SHOULD happen is an ignition switch problem, sticking starter relay, contacts and plunger sticking in the starter, or a short to power in the T40 (relay to starter solenoid circuit). The switch provides a path to ground for the relay and can't cause this problem. I do think someone has messed with the wiring and grounded the relay elsewhere allowing it to crank without the switch being plugged in.
