Old 01-31-2013, 09:14 AM
Yo Nadz Yo Nadz is offline
Vehicle: 2013 Ram 1500 Sport Crew Cab
Trim Level: Sport Crew Cab
Color: Snow White
Rep:160
Yo Nadz has a spectacular aura aboutYo Nadz has a spectacular aura about
I wanna do doughnuts dammit!
Yo Nadz STOMPER Build Thread ~> http://www.ramforumz.com/showthread.php?t=135821
Lifted & Ignorant 2013 Sport Crew
Proud member of IAFF LOCAL 2665
Old 01-31-2013, 12:07 PM
kxlexus kxlexus is offline
Vehicle: 2013 Laramie 4X4 Quad Cab
Trim Level: Laramie Hemi 8 Speed
Color: Maximum Steel Met.
Rep:25
kxlexus is on a distinguished road
the new tuners are different, if your smart you won't have any issues.
Care to explain this?
Old 01-31-2013, 12:23 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Take for example the Bully Dog tuner, If you need to go to the dealer, you just put you ECU back to factory, when the Bully Dog updates the ECU with a performance tune it makes a copy of the Factory ECU info on the DB unit, and another copy on the MicroSD card. So when you upload the ECU back to the Factory settings (because you need to go to the dealer for something), there is only one place in the ECU they can see something has accessed it, its a access counter, so if your smart, you upload the tune you want and leave it like that, not keep changing the tune every day. Access to the ECU could be anything, it could be you went to Pepboys or some other place and they check the ECU for any Errors like when you dash has a check engine light. Most techs will not even check this counter anyways.
Old 01-31-2013, 12:26 PM
ss3079 ss3079 is offline
Vehicle: 2015 Ram 1500 CC 6'4
Color: Blue Streak
Rep:30
ss3079 is on a distinguished road
Same as the DiabloSport products ... save your factory 'tune', load your aftermarket one and run with it ... when it goes in to the dealer for work under warranty, load your saved stock tune back in ...
2013 Ram Sport - CC, 6'4, Hemi/8 Speed
2007 Chrysler 300C, 1970 Dodge D100 (383)
Old 01-31-2013, 12:50 PM
Color: Snow White
Rep:160
Are any of these tuners available for a 2013 yet?
Old 01-31-2013, 12:54 PM
Color: Blue Streak
Rep:30
I highly doubt it as releases for the 2012 tunes have just recently popped up.
Old 01-31-2013, 12:55 PM
Vehicle: .
Rep:4373
not yet, they just cracked in December the 2012, but I am guessing it wont be too long for the 2013 since the encryption for the 2013 is probably the same as the 11 and 12, the problem was the transmission, and with the 8 speed that might slow things down, this is JMO, so take it as it is.
Old 01-31-2013, 01:11 PM
Color: Snow White
Rep:160
Thanks fellas. I'll stay tuned.
Old 01-31-2013, 01:15 PM
Rep:25
How much do the tuners cost?
How much performance increase can I expect over a stock Hemi?
Old 01-31-2013, 01:20 PM
Vehicle: .
Rep:4373
30+hp and you can get specials here at the site from the sponsoring venders, pm them and get the latest pricing
