Old 01-29-2013, 11:11 AM
PeterGriffin's Avatar
PeterGriffin PeterGriffin is offline
Vehicle: 2011 Ram 1500 Sport 4x4
Color: BLACK
Rep:9
PeterGriffin is an unknown quantity at this point
Default BEST Limited Slip Differential Option(s)...?
I realize that a lot of my traction related issues are directly attributed to the HORRIFIC "all season" tires on my truck, but with the little bit of snow we've had here recently, I'd argue that having an open differential isn't helping much either...
I've been all over the road with minimal accumulation, and actually had to put it in 4-wheel high (instead of AWD) just to keep it on the road. My wife's and daughter's MINI Coopers with FWD and Blizzaks rips through the same conditions like a mountain goat 'roid raging!
As much as I'd like to doing a gearing change (have 3.55s now, I'd like 3.92s) contemporaneously to installing a LSD it's a little too spicy a meatball to deal with right now.
So any advice/opinions are appreciated. MOPAR, aftermarket...?
Thanks!
MOPAR trailer brake controller,rubber floor mats & rear view camera*tint*Plastidipped wheels*K&N drop-in*180 thermostat*debadged*running boards DELETED*Front Speakers:Quantum Audio 6-inch*Rear Speakers:Pioneer 6x9*Alpine 4-channel amp*Kenwood Sub amp*Sub:2/10-inch Rockford Fosgate*high/low/fog HIDs
Old 01-29-2013, 11:28 AM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
You have only ONE option....OEM LSD
I have one if you're interested too......
[CENTER][SIGPIC][/SIGPIC]
Old 01-29-2013, 11:39 AM
seanbeckaroo seanbeckaroo is offline
Vehicle: 2009 Ram 1500 Crew Cab
Trim Level: SLT-Big Horn
Color: Blue, Sexy Blue
Rep:66
seanbeckaroo will become famous soon enough
I'm not sure going to 3.92's will make much of a difference for you; if you are going to go that route, go right to 4.10's to see a difference. Someone installed Yokohama Geolandar A/T-S on my 2009, and I hate them in the winter. They are ok on the dry road, but basically useless in snow. I'm going to the Wrangler Duratracs I had on my Bronco, they were awesome tires.
Check out Moes Performance, they have a section there on differentials and gearing that might help you out.
http://moesperformance.com/
Old 01-29-2013, 11:51 AM
Color: BLACK
Rep:9
Hmmm...PM sent!
Old 01-29-2013, 07:18 PM
Color: BLACK
Rep:9
Thanks for the link! I tow a little bit so the 4.10s probably aren't a bad idea at all, and I'd be super pissed if I went through the trouble of changing gearing and didn't go big enough...
Definitely kind of torn on the diff. I don't off-road, I do tow occasionally and I'll likely crank up the HP/torque a little bit. Pretty sure the Detroit locker would be overkill but their True-Trac is looking pretty good...
Old 01-29-2013, 07:25 PM
candy08's Avatar
Rep:213
I would also go lower on the gears, just my preference tho.
Eaton does not offer anything for the zf axle we have. All you can do is oem open carrier or oem lsd
Old 01-30-2013, 12:50 AM
Color: BLACK
Rep:9
?...hmmm...I thought the '12s were a problem but that they did fit the '11s...?
Old 01-30-2013, 01:00 AM
candy08's Avatar
Rep:213
We share the same ZF rear axle. The ZF axle lengths are different than previous years, thats the main issue.
Your thinking of the front, yes the 12 is facked on the front.
Old 01-30-2013, 01:11 AM
Rep:2620
up to 2010 the rear ends were made by AAM
2011 & newer will be a ZF design
another site to check out
http://www.ringpinion.com/
Old 01-30-2013, 09:51 PM
Color: BLACK
Rep:9
Matt @ Moe's Performance was kind enough to clear it up for me and candy08 is absolutely correct, the factory LSD is the only option, there's no aftermarket options for the ZF rear at this time...
