Old 01-29-2013, 01:09 PM
hooter31 hooter31 is offline
Vehicle: 1999 Ram 2500
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
hooter31 is on a distinguished road
Default 1999 Ram 2500 Ball Joints
I have had my 1999 Ram 2500 w/Diesel for 150k mile and love it. Took to tire store to get front tires and an alignment. When I drove it home truck still pulled to the right. I brought it back and they said it needs lower ball joints. No problem except they tell me that the lower ball joints are welded in and pressed and want an additional 2hrs. labor. I just need to know if this is true. It is a 1999 RAM 2500 Sport with a Cummins 2wd. It looks like a 1500, doesn't sit high up at all. Any help is appriciated.
Old 01-30-2013, 04:41 PM
the persuader's Avatar
Vehicle: 2001 Cummins 4x4
Trim Level: SLT Laramie
Rep:326
Welded in? Um no... they are pressed in and require a ball joint press to remove.
Old 02-04-2013, 10:15 PM
Billys68SS Billys68SS is offline
Vehicle: 1999 Ram 1500 LWB RC
Billys68SS is on a distinguished road
Totally agree. Dodge didn't weld the ball joints in. As long as a previous owner didn't you should be fine. It can be labor intensive if there is rust! They should have checked the ball joints before doing the alignment. But if you don't tell them you have a problem a lot of alignment techs will ONLY do what you ask them to.
Hope this helps ya,
Billy
