Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 01-29-2013, 06:36 PM
Alaskan Hemisport Alaskan Hemisport is offline
Vehicle: 2011 Ram 1500
Alaskan Hemisport is on a distinguished road
Default Low Idle and dying?!
Just when I thought I was done repairing the truck, anew challenger appears lol. The other day it was about -40 and my truck would start idling right around 500rpm or a little lower. At one point, my dashboard light up with "check gauges" and noticed my battery gauage showed it was completely dead. I reved it a bit and it came back up, but was still idleing low. I drove down the road a bit, and my truck dies. It didnt sputter or surge or anything, just died. When I tried to start it, it wouldn't even click like the batery was dead. After waiting a bit, it would click like I had a dead battery. And after waiting about 10 minutes, it finally started. The next day, It would only start and run if I was giving it gas. AS soon as I took my foot of the gas, it would die. Any suggestions? Could It be leaking seal somewhere?
Old 01-29-2013, 09:41 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:27
Maddevill is on a distinguished road
First thing I would check id if your battery is any good. A bad battery can send all kinds of weird signals to the ECU causing running issues.
Old 01-29-2013, 10:29 PM
I just got this battery a few months ago, so I sure hope it isnt bad. But it is something to look at. I just got it into a garage, I had to give it throttle at all times to keep it going. I noticed that there was a lot of black smoke from my exhaust in the snow...burning oil? oil leak? not enough oil?
Old 02-12-2013, 07:31 PM
Color: Grey
Rep:27
Black smoke is excessively rich.
Old 02-19-2013, 02:34 AM
it hast put out black smoke since then. I heard that it could be the intake manifold gaskets, so I just replaced those. Also seen I had a cracked fuel injector so I swapped that out too. We're supposed to have a cold front coming in this week, so we'll see what happens....
Old 02-22-2013, 12:49 PM
justbedodge's Avatar
justbedodge justbedodge is offline
Vehicle: 2002 dodge ram
Color: tan
justbedodge is on a distinguished road
Maybe a slacked excellerator cable, possibility it happened to me drove me nuts trying to find out why it would crank then die, $300 plus in parts, sensors, oil change, diagnostic, all to find last thing i ever would have thought, slacked cable.
Old 02-22-2013, 01:09 PM
2006ram2500's Avatar
2006ram2500 2006ram2500 is offline
Vehicle: 2006 ram 2500 QC 4x4
Trim Level: big horn
Color: red
2006ram2500 is on a distinguished road
i had this exact same problem. the pickup would idle real low and when i came to a stop sign it would just die. when i would start it up it kept doing the same thing it would die unless i was giving it some gas. in the end i replaced the alternator and have not had a problem since. side note this was on my 99 but it sounds like an almost identical problem.
