Old 03-11-2013, 09:31 PM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:78
latitud will become famous soon enough
The load capacity on the tire is at MAX inflation. You should be fine with the weight of the 5th wheel and probably truly do not need load range E tires for a 1/2 ton pickup. But your inflation of 55 will be no harm to your rims...even 80 will not harm your wheels. There really is no magical formula for weight at 55 PSI, its not exactly proportional.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 03-11-2013, 09:33 PM
latitud's Avatar
Rep:78
For what its worth, I ran 65 PSI in my load range e tires on my 2002 2500 Diesel ram, and it had rubber valve stems.
