Old 01-30-2013, 07:13 PM
Yo Nadz Yo Nadz is offline
Vehicle: 2013 Ram 1500 Sport Crew Cab
Trim Level: Sport Crew Cab
Color: Snow White
Rep:160
Yo Nadz has a spectacular aura aboutYo Nadz has a spectacular aura about
Default Alternative to "shark fin" antenna?!
I've got 6" clearance between the tip of that stupid shark fin antenna and my garage door which is making me leery about pulling the trigger on a set of Bilsteins, 3" body lift, and a set of 35s. I'm afraid it won't fit in the garage. Curious if anyone knows of a flush mount replacement for that stupid fin? If I "shave" a half inch off it will it affect the performance?
Yo Nadz STOMPER Build Thread ~> http://www.ramforumz.com/showthread.php?t=135821
Lifted & Ignorant 2013 Sport Crew
Proud member of IAFF LOCAL 2665
Old 01-30-2013, 07:33 PM
Porter_'s Avatar
Porter_ Porter_ is offline
Vehicle: 2011 Ram 1500 4x4
Rep:39
Porter_ is on a distinguished road
i don't know if they're compatible but my 2011 came with a flush mount sat antenna. i believe all trucks 2009-2012 have them. they probably went to the shark fin for better reception; mine loses signal pretty easily when driving around downtown between tall buildings. i wouldn't go grinding into your antenna end expect it to still function
2011 Ram 1500 Big Horn 4x4 5.7L
1.5" TGC Leveling Kit, 305/55/20 Toyo Open Country A/T's
Old 01-30-2013, 07:59 PM
Color: Snow White
Rep:160
I think that's only for am/fm. The fin I believe is NAV/Satelite.
Old 01-30-2013, 08:14 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Then he could always cut a slit in the top of his garage for the fin to slide in if its too high
Old 01-30-2013, 08:33 PM
Color: Snow White
Rep:160
I can't say that thought didn't cross my mind lol.
Old 01-30-2013, 08:51 PM
ShaneDiddy ShaneDiddy is offline
Vehicle: 2013 Dodge Ram 1500 Sport
Rep:19
ShaneDiddy is on a distinguished road
I'm sure there is one ..my Jeep has Sat and I don't even know where the antenna for that is, and my acura had NAV/SAt and its antenna was much flatter than the one on the 2013 Rams
Old 01-30-2013, 09:12 PM
Zixxer Zixxer is offline
Rep:35
Zixxer is on a distinguished road
Has to be a reason for the fin...I had a 2012 and it was fairly flat but I know the sat and gps would go offline even under a bridge, a smaller bridge. This setup seems to get the better sat reception perhaps due to the side to side bounce? I wouldn't grind it without determining exactly how it works inside.
2" Mopar Lift/285/65/20 BFGs/DB Corsa Exhaust/Mopar flares/Lo Pro Tonneau/Line-X Premium/Ez Down tailgate/Catch-Can/Moe's 87mm TB
Side Molding/345 Emblems/Husky Splash Guards/Honeycomb Grill/25% Tint/Silver Rally Stripes/Crux Rear Camera and VIM
Removed - Air Grabber - filtering is not very good
Old 01-30-2013, 09:32 PM
Cookie Monster Cookie Monster is offline
Vehicle: 13 1500 Laramie Crew 6'4
Trim Level: Laramie 8Speed 4x4
Color: True Pearl Blue
Rep:71
Cookie Monster will become famous soon enough
This is basically what a shark fin antenna looks like inside. It is possiable to modify the shark fin molding. first you would have to remove the fin from the roof. Then carefully peel the actual antenna (copper) using a heat gun. It basically a plastic infused with copper that has adhesive. once this is done one could cut away from the fin and remold it with fiberglass. Then simply paint to match then re-apply the Antenna (copper) with some glue. Basically the bottom or base is where there is a PCB board where this attaches to.
The only issue maybe with performance when you do the mod. But it shouldn't be that bad. speciially if you re apply it at the top flat part you created.
Also there is a GTR Antenna it isn't as tall as a shark fin. It mostly used on Nissans but should replace most shark fin antennas. As you can see its bassically a shark fin with the top cut off and flattened.
Old 01-30-2013, 11:51 PM
Color: Snow White
Rep:160
I wonder if this is something a audio shop could do without raping my wallet.
Old 01-31-2013, 02:29 AM
2013Sport's Avatar
2013Sport 2013Sport is offline
Rep:20
2013Sport is on a distinguished road
Yo,
If they start talking like they're gonna attempt to build an atom bomb... its raping time lol.
JR
