Old 02-02-2013, 12:45 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
Originally Posted by Barbarian 69 View Post
Wow thanks for the complements from everyone.
Sinistersix, as fastNugly mentioned I was able to fit the 37" Nittos on with both the 3" Zone body lift + the 2.5" leveling kit I installed for a total of 5.5” lift. I also have the adjustable Bilstein 5100’s but I left them at the stock height as I already had the leveling kit in. As for comparing the Zone body lift to the PA I read a lot before purchasing and after seeing the extremely beefy bumper brackets that came with the Zone compared to what I saw in the PA kit was why I went with Zone and couldn’t be happier that I did as it was an easy install. fastNugly, I’m not sure what the stock offset on the ’08 wheel is but that’s what these are. One thing that may have helped though is that the Nitto 37” Trail Grapplers are listed at 37x12.50R20LT where most other Mud tires I looked at in a 37” were listed as 37x13.50R20LT so maybe the 1” difference in width helps too?
Correct. The 12.5" wide tires are huge.
That being said.....on a 4th gen the stock wheels are just too close to the a arm and there is no way those tires would fit on our without some spacers or aftermarket wheels.
sales@revelperformance.com
Old 02-02-2013, 12:51 PM
Revel Performance's Avatar
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
Barbarian that truck looks killer with those 37's
Thanks
Jeremiah
Discount Auto Performance
Old 02-02-2013, 12:52 PM
REVEL PERFORMANCE
Vehicle: MOPAR
Rep:931
You can barely run stock tires and wheels on a 4th gen with a lift, I had less than a pinkies width between the a-arm wasn't comfortable with it so had to get some spacers
Thanks
Jeremiah
Old 02-02-2013, 12:53 PM
sinistersix sinistersix is offline
Vehicle: 2011 Ram Sport
sinistersix is on a distinguished road
Where did u purchase the zone kit?
Old 02-02-2013, 01:32 PM
Revel Performance
Rep:1804
This can be purchased from any zone or zone/BDS distributor
But the PA is a good kit and Jeremiah may have a deal for you and a slightly used set if interested
Old 02-02-2013, 01:39 PM
Barbarian 69's Avatar
Barbarian 69 Barbarian 69 is offline
Vehicle: 2008 Dodge Ram Big Horn QC 4x4
Color: Electric Blue
Rep:12
Barbarian 69 is on a distinguished road
I purchased my Zone body lift directly from Zone. I just called them up, placed my order and had it at my door in about 2 days as they have same day as ordered shipping. A friend of mine who has a lift in his garage installed it with me in two days. I thought the kit was well made, complete and the bumper brackets look to be stronger then stock brackets. You do need to cut off the factory bumper brackets and weld the Zone brackets on though. I also had my exhaust tip cut and moved up 3” to make it look factory instead of hanging 3” low.
2008 Dodge Ram 1500 Bighorn QC 4x4 with the 5.7 Hemi, Zone 3" Body Lift, Bilstein 5100's.
Old 02-03-2013, 07:22 PM
Zmuch Zmuch is offline
Color: Electric Blue Pearl
Zmuch is on a distinguished road
Default Love It!
Zmuch,
I have a 2008 Quad Cab that has a 2.5" leveling kit along with a 3" Zone body lift. With this I was able to add 37" Nitto Trail Grapplers on the stock rims without any rubbing so this will show you kind of what your truck will sit like.
That's exactly what I want. How much does each item cost a piece, and then with installation?
Old 02-03-2013, 07:46 PM
Revel Performance
Rep:1804
Spacers - $80-250
3" Body lift - $400
Install - free if you do it
If you need pricing hit either myself or Jeremiah of Discount Auto Performace for spacers and/or body lift
Old 02-04-2013, 12:39 AM
Default Cool, thanks for the reply
Spacers - $80-250
3" Body lift - $400
Thank you! I can just hit you up on here?
Old 02-04-2013, 01:12 AM
Revel Performance
Rep:1804
Yes sir
Find us in the vendor section under Discount Auto Performance or send me a PM
