Old 01-31-2013, 02:06 PM
superjuggie's Avatar
superjuggie superjuggie is offline
Vehicle: 2010 Dodge Ram 1500 5.7L
Trim Level: Sport 4x4
Color: Metallic Black
superjuggie is on a distinguished road
Default where to hide my diablosport OBD2 cable?
I'm about to hook up my trinity into my 2010 and it's unbelievably cold outside so i don't really have time to mess with anything lol.
but how are you guys running the OBD2 cable so it's hidden behind the dash and run up into the programmer itself?
Old 02-05-2013, 01:36 AM
FSTASFCK FSTASFCK is offline
Vehicle: 2010 Dodge Ram Big Horn
Rep:108
FSTASFCK will become famous soon enoughFSTASFCK will become famous soon enough
I mounted mine in the corner of the windshield and ran wire to the corner and behind the dash to the connector...looks great IMHO...check out my build thread for pics
Old 02-05-2013, 03:23 PM
Divi Divi is offline
Vehicle: 2011 Ram 1500 Crew cab
Trim Level: Sport, loaded
Color: Obsidian Black Pearl
Rep:112
Divi will become famous soon enoughDivi will become famous soon enough
Ran mine from the OBD2 port under the dash to by the drivers door. Then up and popped it out in the bottom of the windshield where the A-pillar meets dash. Looks really clean and you can easily remove the unit and obd-2 if you need to.
There are also other options of using a OBD-2 splitter, which essentially gives you a second OBD-2 to plug inot so you still have your stock one for diags at the dealer and what not or you could do like i did with my Subaru a few years back and hard wire it in.
2011 Ram 1500 crew OBP, Airraid Cold air, Bestop roll up, Lockpick v5, custom carbon interior trim.
Old 02-05-2013, 04:26 PM
matt085's Avatar
matt085 matt085 is offline
Vehicle: 2009 dodge RAM SLT HEMI
Color: BLUE
Rep:59
matt085 will become famous soon enough
http://www.ramforumz.com/showthread.php?t=101944
this is how i mounted my trinity. the cable is going from the connector behing the dash to where you see in the pictures.
Old 02-07-2013, 10:45 AM
Rep:112
eww, that does not look good at all. holes in trim that cost over $100 a pop, not a good idea.
Old 02-08-2013, 06:54 PM
matt085's Avatar
Color: BLUE
Rep:59
if you are thinking about the price of each item you won't change or mod anything. wheres the fun in that?
Old 02-10-2013, 01:30 AM
how did you get it behind the dash? did you just lift a corner up or something??
Old 03-11-2013, 07:25 PM
BC18471's Avatar
BC18471 BC18471 is offline
Vehicle: 2011 Dodge Ram
Color: Gray
Rep:38
BC18471 is on a distinguished road
Can anyone help me out with this? It doesn't seem like the wire/ends will fit. Do I have to notch the dash to get it to fit or should the wire fit without any cutting?
Thank you.
Brian
Custom Katzkin leather, Magnaflow 14" with Y, Mopar CAI, Moroso Catch Can, 180* t-stat, Switchback Front turn signals, All LED lighting, Kenwood DNX6180, Cabin air filter, Smoked Tails and 3rd, Audiovox backup camera
Old 03-14-2013, 01:39 AM
i ended up just running the cable inside of my door weather strip and wrapped the leftover cable around my emergency brake lol.. looks hidden enough until i buy the pillar mounts and do it right.
