upper/lower control arm bushings....problemss..... - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 01-31-2013, 03:45 PM
JtmDevilDog's Avatar
JtmDevilDog JtmDevilDog is offline
Vehicle: 05 Ram 1500 Quad Cab Daytona
Trim Level: Daytona
JtmDevilDog is on a distinguished road
Default upper/lower control arm bushings....problemss.....
Has any replaced tbe bushing on their upper and lower control arms?? How much and how difficult? Ive got a raddeling noise up front, ive checked everything and when i looked at the bushings they looked dry rotten and loose. So thats the only thing i can think of what it could be.
Old 02-10-2013, 02:30 PM
burn1ch burn1ch is offline
Vehicle: 2005 Dodge Ram Daytona
Trim Level: Daytona
burn1ch is on a distinguished road
The upper ball joint is part of the control arm and is replaced as an assembly. The lower ball joint is pressed in and serviceable if need be.
Check your sway bar end links and bushings for play. They will make all sorts of noise when the go bad. They are easy to change out and could very well be your problem.
