Old 01-31-2013, 06:49 PM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
Default help!!!
WTF!!! just got finished installing the 84mm fastman throttle body and everything was all good tell I try to put the K&N cai. back on. The neck is smaller then the throttle body way smaller!!
SPONSORED BY
BULLY'S PERFORMANCE
Old 02-01-2013, 10:38 AM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
Should have bought the 87mm moes one. I did. Direct swap. Perfect fit!!
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 02-01-2013, 10:49 AM
Flaminchiten Flaminchiten is offline
Vehicle: 2010 Ram 1500
Rep:42
Flaminchiten is on a distinguished road
I thought I read somewhere that the 2012 throttle body was a little different or maybe it was the 2013, I would contact moes and see if they can give more information
Old 02-01-2013, 11:03 AM
Chris b's Avatar
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
Got the fastman cheap!!! So i'm happy with it, its the K&N cai that's the problem?
SPONSORED BY
BULLY'S PERFORMANCE
Old 02-01-2013, 11:04 AM
Outlaw's Avatar
Color: Bright white
Rep:435
My vararam goes on my 87 like a glove.
[/CENTER]
Old 02-01-2013, 12:58 PM
Blue thunder Blue thunder is offline
Vehicle: 2011 dodge ram quad cab sport
Color: Blue
Blue thunder is on a distinguished road
Something isnt right. Both me and my buddy I have a 2011 and he has 2012 both have fast man throttle body and k&n cai no problems with fitment.
Old 02-01-2013, 01:43 PM
Chris b's Avatar
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
Your K&N neck aint smaller than your throttle body???
SPONSORED BY
BULLY'S PERFORMANCE
Old 02-02-2013, 04:02 PM
Color: Blue
No we didn't notice any difference in size from stock to fastman?
Old 02-02-2013, 08:52 PM
I push the skinny pedal
Rep:3277
Chris, how much undersized is the K&N collar?
The 2013 has a different TB, '05-'12 are the same on all the hemis whether it's a 5.7L, 6.1L, or 6.4L. The only difference between the '03/04 is it's a slightly different connector, but the mechanics are all identical.
Both the Moes and Fastman TBs are OEM cores that are ported, the outside diameter is the same as the stock one he took off. The reason he went with the 84mm is because the mods he has will take advantage of the extra volume flow that an 80mm diameter butterfly TB can't flow.
The problem is with the K&N coupler, which is a simple fix. My old AirAid was a bastard to get over the TB neck, so I just measured the outside diameters of the inlet tube and TB and ordered a silicon expansion fitting that would match.
Kurtis
Old 02-02-2013, 09:40 PM
Chris b's Avatar
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
Thanks, that's what I did to day. order a specter 4" to 3.5" and im pretty sure this will fix it. I will have to cut some off the K&N cai. Its like the neck of the cai will almost fit in the throttle body. lol
SPONSORED BY
BULLY'S PERFORMANCE
