Old 02-02-2013, 10:31 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
I'm confused. If the fastman TB is the same OD as your original, and your K&N fit your original, why doesn't it fit the fastman?
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
Old 02-02-2013, 10:41 PM
I push the skinny pedal
Rep:3277
Actually, Chris, do you know if it's an Fastman 847 or the 801. The 847 used a different OEM cast compared to the 801, it had a thicker neck. Mother Chrysler decided to make 2 different castings on several models/years across the board, and normally isn't an issue because the stock air box coupler has a lot of play in it. The 801 should have what looks like a machined ring but the 847 should just be a solid outside circumference. The easiest way to tell is the 847 has a ridge along the bottom of the TB but the 801 doesn't.
I bet that's what the issue is. When you order them directly from fastman he makes you look at what TB you have and you'll get an exact match.
Kurtis
Old 02-03-2013, 02:13 AM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
That's sounds about right. I got it used from someone on here. My stock throttle body had a lip where the cai goes on but this one does not. So is this bad??? do i have the wrong throttle body?
SPONSORED BY
BULLY'S PERFORMANCE
Old 02-03-2013, 09:11 PM
Rep:3277
The throttle body internals are the same, the only difference is the outer lip. The coupler should work for you, I just worry that 4" is a little too big.
Kurtis
Old 02-03-2013, 09:32 PM
Chris b's Avatar
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
Well I ordered the spectre 4" to 3.5" but it has a insert so it can be
used as 3.75" to 3.50"
SPONSORED BY
BULLY'S PERFORMANCE
Old 02-03-2013, 09:42 PM
Rep:3277
You should be good if it's got the insert.
Kurtis
Old 02-03-2013, 09:46 PM
Chris b's Avatar
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
honestly now that I've looked at it better I think I just had the clamps in the wrong place and maybe over tighten one of them. lol but the blue spectre is going to look better anyway.
SPONSORED BY
BULLY'S PERFORMANCE
Old 02-07-2013, 04:20 PM
Chris b's Avatar
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
Here's the fix for now. Cut about 2" off the K&N cai tube and put the spectre 4" to 3.5" on top of the 84mm fastman.
SPONSORED BY
BULLY'S PERFORMANCE
Old 02-07-2013, 05:13 PM
Rep:3277
Looks nice and clean
Your engine bay is a prime candidate for some Billet-Crack... I mean Billet Tech stuff
Kurtis
Old 02-07-2013, 05:24 PM
Chris b's Avatar
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
I've got there blue catch-can. and I wanting the rest but kinda waiting on this sale I keep hearing about 40% off.
SPONSORED BY
BULLY'S PERFORMANCE
