Hot wire on mirror plug for detector mount - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior Modifications - Custom Audio / Video
Old 07-15-2012, 02:18 AM
Pelikan Pelikan is offline
Vehicle: 2015 Ram R/T
Trim Level: R/T
Color: silver
Pelikan is on a distinguished road
Default Hot wire on mirror plug for detector mount
I am installing a Blendmount radar mount on my 2012 Ram R/T. I need to know which colored wires to tap into on my rear view mirror electrical plug (1 for power when engine is on and 1 for ground). I have mounted these in several of my other vehicles, but I don't know the color scheme on the Ram truck mirror plug. The radar detector (Beltronics 955) plugs in with an 8" wire with 2 pins that stick into the connections on the plug in back of the rear view mirror. Anyone know which color wires I should tap into? Thanks.
Old 07-18-2012, 02:15 PM
vampre99 vampre99 is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Lone Star
vampre99 is on a distinguished road
Did you ever get a reply to this? I have an Escort 8500 I want to install the same way?
Old 07-20-2012, 08:36 AM
phawk711 phawk711 is offline
Vehicle: 2004 Dodge Ram 1500
phawk711 is on a distinguished road
I am also wondering if you found anything out? I ordered an iRadar and I plan on mounting mine under the rear view mirror. I checked the connections on the mirror plug and it's pushing right around 14v so it should be okay for the detector. I ordered the wiring kit for it and it comes with a fuse on the hot wire....anyone know if I need that fuse or can I just connect straight from the detector to the mirror plug??
Old 07-20-2012, 10:45 AM
Firehawk's Avatar
Firehawk Firehawk is offline
Vehicle: 2011 Dodge Ram
Trim Level: Express RCSB/2WD
Color: Mineral Gray Metallic
Firehawk is on a distinguished road
Send a message via Yahoo to Firehawk
Is this the wiring harness you have?
http://ramforumz.com/showthread.php?t=105093
http://store.blendmount.com/mirrorta...px?Thread=True
↑↑↑↑↑↑ My truck modifications list is located in my forum profile. → → →
Old 01-31-2013, 05:58 AM
misfit1981's Avatar
misfit1981 misfit1981 is offline
Vehicle: 2012 Ram 1500 Quad Cab 4x4
Color: Silver PS2
Rep:45
misfit1981 is on a distinguished road
I'm interested in the iRadar and would like to mount it in the same spot as well. I see that it comes with a cigarette lighter power cord, but is there a kit to hard wire it? If not I guess I could splice the cigarette lighter wires, but the idea of having a fuse in line on a hard wire kit makes me a bit more comfortable.
I have the RHB Garmin Nav and uconnect. If my iphone is connected to the iRadar and I get a phone call, and I answer that phone call using the uconnect, will my iRadar still be affective? I've spent a few minutes trying to google that info - but I haven't found anything on the subject. Any help would be appreciated!
"To be prepared for war is one of the most effective means of preserving peace." -George Washington
Old 02-01-2013, 12:46 AM
hemirae hemirae is offline
Vehicle: 2009 Dodge Ram
Trim Level: Laramie CC
Color: Black Crystal Pearl
hemirae is on a distinguished road
Mirror-inside rearview (except base) - (mirror int jumper) 7 way cavity circuit function
1 f943 20pk/lg fused ignition run/start control output
2 z911 20bk/lg ground
3 l1 18wt/lg backup lamp feed
4 - -
5 - -
6 - -
7 - -
Old 02-01-2013, 12:48 AM
Mirror-inside rearview (hands free) - (mirror int jumper) 16 way cavity circuit function
1 x712 22dg/lb microphone 1 in (+)
2 x792 22lb/dg microphone in (-)
3 x722 22lb/dg microphone 2 in (+)
4 - -
5 - -
6 - -
7 - -
8 z911 20bk/lg ground
9 l1 18bk/lb backup lamp feed
10 x835 22or/gy sensor ground
11 - -
12 - -
13 f943 20pk/lg fused ignition run/start control output
14 - -
15 x793 22dg/yl microphone feed
16 - -
Old 02-01-2013, 12:54 AM
(+) pink/light green
(-) black/light green
I have an 09 and used the above wiring diagram when I hardwired my 9500ix.
Old 02-01-2013, 04:33 PM
misfit1981's Avatar
Color: Silver PS2
Rep:45
Do these prices from Amazon seem ok? Are all Cobra hardwire kits compatible with all Cobra radar detectors?
I am planning on a crosscountry drive this summer and am looking for a "best for the money" option here. If anyone has other radar detector brand model options, I'm open to suggestions. Thanks!
