Old 02-01-2013, 05:46 PM
sethmark sethmark is offline
Vehicle: 2009 Ram 1500 SLT
Rep:19
sethmark is on a distinguished road
Default Catastrophic water pump failure
Water pump in my 4.7l 09 failed today. The belt started squealing then spraying coolant everywhere. Pulley is way loose.
Anyone else change one? Any tips?
Old 02-01-2013, 06:26 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:427
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
Any chance your still under warrantee?
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner,GY Armortracs, 215,000 miles To Hell and back. 14.2/96 mph NEDW
Old 02-01-2013, 07:53 PM
Rep:19
Hell no. I'll fix it.
Old 02-02-2013, 07:50 AM
Rep:1909
There's nothing to it. If you have basic hand tools, you can do it in an hour or so. The hardest part is getting all the air out of the cooling system.
Old 02-02-2013, 08:34 AM
Rep:19
Any trick? I assume that leaving the cap off and turning the heater on is the right way without the suction tool?
Old 02-02-2013, 01:42 PM
frickenbored's Avatar
frickenbored frickenbored is offline
Vehicle: 2012 R/T, 2000 Ram Off Road
Trim Level: R/T / Larmie
Rep:73
frickenbored will become famous soon enough
You should have a bleeder screw in the aluminum housing right where the upper radiator hose goes into the engine. Take it out with an allen head socket or allen wrench, i can't think of the size off the top of my head. Fill the cooling system through that hole with the radiator cap off (you'll need a small funnel) When coolant starts to overflow from that bleeder hose put the screw in and finish filling it from the radiator, shouldn't take much more.
I fill it through that small hose because it gets directly into the block much easier than if you just go through the radiator, all the air will get pushed out through the radiator. Thats how I fill every 3.7 and 4.7, I never have to bleed the system after and have never had any problems doing it like that. Oh, and have fun
Chrysler Dealership Engine, Trans, Axle "Heavy" Tech of 3 years
Check em' out:
Old 02-02-2013, 01:46 PM
Rep:73
Heres a picture of where the bleeder screw is, in case you've never noticed it before:
Check em' out:
Old 02-02-2013, 05:15 PM
Rep:19
Yep. It failed.
http://youtu.be/JwEMkXK5zqA
Thanks for the help guys. It seems to be bled fine filling slowly from the radiator neck. I ran it the the cap off for about 15 min til the thermostat opened and the electric fan turned on. Ran the heater for a while too and it's stable at 197*.
Old 02-02-2013, 05:17 PM
Rep:1909
Sounds like you got it handled. Not hard to do at all, is it?
Old 02-02-2013, 06:42 PM
Rep:19
I've done a lot of water pumps. This one. Was EASY. WAY EASY.
