Old 02-02-2013, 01:55 PM
Coastline's Avatar
Coastline Coastline is offline
Vehicle: 2013 Ram 1500 4X4
Trim Level: Laramie Longhorn
Rep:15
Coastline is on a distinguished road
Default Re-chargable Flashlight In Rambox
I wanted to mount my rechargeable flashlight in the cab like I had done in my previous truck but thought, why not mount it in the Rambox. Has anyone else done this and if so give me some details or ideas as to figure out the best way to do this. Thanks.
Old 02-03-2013, 01:18 AM
HorseMan's Avatar
HorseMan HorseMan is offline
Trim Level: Longhorn Crew 4x4
Rep:139
Neat idea. Let us know how wiring goes, and send pics! I always liked the plug in Toyota puts in their beds of the Tacoma. Wonder if that is an option.
Old 02-03-2013, 01:27 AM
Cookie Monster Cookie Monster is offline
Vehicle: 13 1500 Laramie Crew 6'4
Trim Level: Laramie 8Speed 4x4
Color: True Pearl Blue
Rep:71
Cookie Monster will become famous soon enough
I was actually thinking of adding a HD power inverter in one of the rambox's when I get my Laramie. I would just run a 4-AWG off the positive battery term with a inline fuse at the battery. Then run a ground from bellow to the frame. was also going to add a relay to it from RUN on fuse so that the inverter only operates when the truck is running.
Now for you to run just rechargable flashlight ( I assume its a 12v rechargable one) then you don't need that big of a cable. You may also want to attach it with a relay to a RUN fuse so that it only charges when the truck is in acc or run. that way it isn't draining the battery.
Old 02-03-2013, 07:35 AM
Coastline's Avatar
Rep:15
The way I had it hooked up in my other truck was straight to the battery. If I was not going to start truck for several days I would just remove the flashlight.
I think I'll try this but, I think I'll wait until it warms up a bit. Thanks for the input guys.
Old 02-03-2013, 08:22 PM
Rep:71
Just remember to add a inline fuse at the battery. this will protect the electrical system incase of any shorts.
Old 02-04-2013, 08:12 AM
Coastline's Avatar
Rep:15
Yessir...Thanks
Old 02-04-2013, 12:15 PM
Scooped Scooped is offline
Vehicle: 2013 Ram 1500 8 speed-ordered
Color: White/White Gold accent
Scooped is on a distinguished road
Coastline - check this out.
http://www.leeparts.com/dodge_ram_ds...er_outlet.html
Old 02-04-2013, 02:44 PM
Coastline's Avatar
Rep:15
I really like that Scooped. Now I have to find my plug...I cut it off so as to straight wire it to the battery. I really like that though, good idea.
Old 02-04-2013, 03:04 PM
I wired two of them (one in each Rambox) and an inverter for charging my power tools while I'm driving - worked out really well.
Old 02-04-2013, 03:24 PM
Coastline's Avatar
Rep:15
I think I'll order 2 of 'em also and use the other one for the same thing as you. Thanks again for the heads up.
