Ambient air temp indicator can't be repaired - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
Old 02-02-2013, 04:23 PM
Sami6 Sami6 is offline
Vehicle: 2013
Trim Level: 1500 Express
Color: Pearl Blue
Sami6 is on a distinguished road
Default Ambient air temp indicator can't be repaired
Picked up a new 2013 Ram last week. The ambient air temp indicator on the dash is consistently 8 degrees off.
Went to the dealer that sold me the truck. They changed the sensor located on the underside of the driver outside mirror. The problem still exists. Service manager said "sorry we can't fix it".
That is so wrong on so many levels. When I went into the dealer I had only 175 miles on the truck. It may be insignifigant to the dealership and others but a) I do depend on it b) I expect it work properly.
It isn't a Lamborgini but I did pay 35 K and worked for every one of those dollars.
Pardon me for rambling, I think the dash unit needs to be changed..... any thoughts out there?
Old 02-02-2013, 04:31 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Contact another dealer in your area and see what they say, they get paid for warranty repair work, I don't see why they have to stop at just the outside sensor, what does another truck on the dealer lot say? if that don't work, Contact Chrysler and make a complaint.
Old 02-02-2013, 04:36 PM
Vehicle: 2013
Color: Pearl Blue
My intention is to contact the Customer Care people momentarily.
The dealer actually put my sensor in another 2013 on the lot and it worked fine.
The put a new sensor in my truck and it was still 8 degrees off.
Old 02-02-2013, 04:39 PM
Ford Apostate Ford Apostate is offline
Vehicle: 2013 1500 4x4 CC 5'7" Rambox
Trim Level: Longhorn/8 Speed/Air
Color: Mineral Gray
Rep:17
Ford Apostate is on a distinguished road
Wow, that dealership really has great troubleshooting skills. We replaced your sensor that we verified to be good and that didn't fix it so we give up.
Old 02-02-2013, 04:43 PM
Vehicle: 2013
Color: Pearl Blue
Not an abundance of effort.
I am trying to be patient.... I could be a bull in a china shop and I didn't want to grab the service manager by the scruff of the neck just yet.
It is called "progressive persistence"
Old 02-02-2013, 05:56 PM
Zixxer Zixxer is offline
Vehicle: 2013 Ram 1500 Sport
Rep:35
Zixxer is on a distinguished road
Mine is off, and from what I gather, many others are as well. I just assumed they will release a flash update or something.
2" Mopar Lift/285/65/20 BFGs/DB Corsa Exhaust/Mopar flares/Lo Pro Tonneau/Line-X Premium/Ez Down tailgate/Catch-Can/Moe's 87mm TB
Side Molding/345 Emblems/Husky Splash Guards/Honeycomb Grill/25% Tint/Silver Rally Stripes/Crux Rear Camera and VIM
Removed - Air Grabber - filtering is not very good
Old 02-02-2013, 05:57 PM
Resident Technician
Rep:1915
Assuming there are no DTC's in the IPC or PCM and no TSB's are located (which there are not any, currently), the IPC self test has passed, resistance is verified in the ATS, the dealership is pretty much stuck with escalating the case to STAR for any other information regarding troubleshooting. Replacing a part that tested good in an attempt to fix your problem is actually going above and beyond what they're supposed to do.
Old 02-02-2013, 06:39 PM
Color: Mineral Gray
Rep:17
I don't know what all that means but why can't they swap out other components?
Old 02-02-2013, 07:24 PM
Vehicle: .
Rep:4373
Assuming there are no DTC's (Diagnostic Trouble Code)'s in the IPC (Instrument panel cluster) or PCM (Powertrain control module) and no TSB's (Technical Service Bulletin)'s are located (which there are not any, currently), the IPC (Instrument panel cluster) self test has passed, resistance is verified in the ATS (Air Temperature Sensor), the dealership is pretty much stuck with escalating the case to STAR (Service Technical Assistance Resource) for any other information regarding troubleshooting. Replacing a part that tested good in an attempt to fix your problem is actually going above and beyond what they're supposed to do.
Old 02-03-2013, 01:40 AM
rjmlakota's Avatar
rjmlakota rjmlakota is offline
Trim Level: Sport Crew Cab
Color: Mineral Gray Metallic
Rep:18
rjmlakota is on a distinguished road
This has been talked about on these forums many times. There are tons of owners that are having the same issue. I am one of them. My outside temp is consistently showing a 6-8 degree difference.
Hopefully Ram comes out with a fix. Be patient grass hopper.
