PCM Fuse to reset adaptives - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-03-2013, 09:16 AM
Yellow Jacket Yellow Jacket is offline
Vehicle: 2009 Dodge Ram 1500
Yellow Jacket is on a distinguished road
Default PCM Fuse to reset adaptives
Hey everyone,
I know you can reset your adaptives by pulling the PCM fuse, turning the key to on and waiting 30 seconds, then replacing it. But I've searched on here and couldn't find WHICH is the PCM fuse? Where is it located? Anybody have a good picture or diagram? I pored over the Service Manual, but I suck at reading wiring diagrams. Also, I had a hard time correlating that with what you can actually see in the fuse box.
Any help would be great. Thanks!
Old 02-03-2013, 05:34 PM
Resident Technician
Rep:1915
I never really understood why people are so worried about resetting adaptives. What difference does it make if your adaptives update from the current settings or from default settings?
Old 02-03-2013, 07:08 PM
Well, I'm buying the truck used next week, and I'm kind of OCD so I would like the truck to start from default settings to learn my driving style, as opposed to superimpose my style over the previous owner's.
Can you tell me what fuse it is? Thanks!
Old 02-04-2013, 04:49 PM
Resident Technician
Rep:1915
It has nothing to do with how you drive, but rather how much fuel the engine requires in a specific rpm band. If I remember correctly from school, the adaptives are stored in non-volatile memory and need to be reset with a scan tool.
Old 02-04-2013, 04:59 PM
Hmmm, interesting. On the modern Challengers, adaptives are reset by pulling Fuse #2. Some people have reported better track times when you do that, but I'm not aware of anyone actually getting dyno numbers.
Old 02-04-2013, 05:17 PM
Resident Technician
Rep:1915
Fuse M33 is for the A209 circuit which feeds B+ to the PCM.
Old 02-05-2013, 07:14 AM
Thanks RamTech, I appreciate it. It probably doesn't make any difference like you said, but coming from the Mopar racing side, we do it all the time so I figured it couldn't hurt.
Old 06-19-2017, 04:25 PM
Ironwalkerrick Ironwalkerrick is offline
Vehicle: 2014 Dodge Ram
Ironwalkerrick is on a distinguished road
Default Hey calling out to Ramtech
Hey Ramtech, maybe you could answer this. While I was testing a harness for the radio upgrade from the 5 inch screen to the 8.4 with the new upgraded bezel and custom wiring harness, I did something to the pcm I think, basically I did the swap, harness worked perfect, I tried an incomplete harness that I built for someone else and since then lost the hard controls for hvac but it all works on the stereo interface. Also the volume went with it and the tow/haul and traction control for some reason, not even connected to anything and I've checked, there's no loose connections. I've got my original harness back in, it worked before and now it doesn't. I found a couple loose pins on the harness that I made for someone else, tested it on my buddies truck, works perfect, tested my current harness in my buddies truck, works perfect. What did I do to my computer and can a flash from the dealership reset it? 2014 ram ST, thanks in advance for any input
