Old 02-03-2013, 04:11 PM
1BAD95 1BAD95 is offline
Vehicle: 1995 Dodge Ram 1500
1BAD95 is on a distinguished road
Default Auto to Manual
I have a 95 1500 with an auto trans and a 5.9 360. I was wondering how big of a job it would be to convert it from be an auto to a manual. Also where would I be able to find a manual transmission for my truck if I wanted to do the conversion? Is it even worth all of the work to change everything? Any feedback would be great! Thanks, Matt
Old 02-04-2013, 12:08 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
Whole lotta work and it wont be easy. You'll need:
PCM
NV3500 trans
Clutch
Clutch Peddle Assm.
Slave Cylinder
Drive-shaft
Cut a hole on the tunnel
There is a difference between auto and manual tran drive shafts. Trucks equipped with manual trans had a large diameter drive-shaft than the auto. NV3500 manual trans is a one piece aluminum trans used on half ton trucks. You can use a NV4500 manual trans from a 3\4 ton truck, good luck trying to find either one. Manual trucks are somewhat rare. Not a lot were produced so locating necessary parts and peddle assm is going to be tough.
