Rear end noise - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 02-04-2013, 08:15 AM
Foxtooth Foxtooth is offline
Vehicle: 1998 Dodge Ram
Foxtooth is on a distinguished road
Default Rear end noise
Figured I'd ask another question while I was on here.
Wondering if anyone knows what different option rear ends are swappable between trucks. I have a major pinion bearing noise but not the money to have someone fix it properly. I was wondering if I can just swap in a newer style rearend or maybe a less technical one. Currently have the Chrysler rearend with trac-loc. I'm not looking to weld/cut/modify my truck or new axle to make it fit. Am hoping to find a direct bolt in or close fit, which is not always possible.
If I cannot find any real options I will just start saving $.
Old 02-04-2013, 04:44 PM
Resident Technician
Rep:1915
Honestly, I don't see how replacing the rear end will be any cheaper than replacing pinion bearings. Then there's the chance the rear end you get may be on it's last leg as well. What exactly do you mean by a less technical rear end?
