Old 02-04-2013, 11:03 PM
Tall Hat Tall Hat is offline
Vehicle: 2008 Dodge Ram
Tall Hat is on a distinguished road
Default Need help with codes. Tryin to figure out what I should do next
P 2314 Ignition coil "E" secondary circuit
P 0305 cylinder 5 misfire
I am just tryin to think what I should do next. Should I change the plugs on that cylinder or the coil pack? Or both? Do I need to change the wire too?
Old 02-05-2013, 08:40 AM
tjbiker031's Avatar
Vehicle: 2002 Dodge Ram
Trim Level: SLT - Quad Cab
Color: Graphite Metalic
Rep:118
try moving the coil that is misfiring to see if the misfire follows the coil. If it does thats your problem, if not then could be either spark plug (probably) or and issue in wiring.
How many miles on the truck? Last time plugs and/or coils been replaced?
Old 02-05-2013, 10:45 AM
It has 56000 on it. I dont know if the plugs or coils have been changed before, and I havent done it yet.
Do you know which cylinder 5 is?
Old 02-05-2013, 10:52 AM
Rep:1845
P2314 is actually for #5 insufficient ionization on the secondary circuit and is typically caused by a failed coil. Cylinder #5 is the third one from the front on the drivers side. Given the mileage on your truck, I would recommend changing the plugs and replacing the #5 coil.
Old 02-05-2013, 01:27 PM
Thanks RamTech. I just ordered a coil and went ahead and got new top plugs since its past time to change em. Hopefully this will fix my problem.
