Old 02-04-2013, 11:27 PM
Jross360's Avatar
Jross360 Jross360 is offline
Vehicle: 2006 Dodge Ram
Jross360 is on a distinguished road
Default Airbag light on after install(s)...
Soo today I installed HID lows, fogs, and new head unit. Everything went together pretty smoothly, which was nice. But after I get the CD player hooked up, I take a test drive to check out the new lights, and my lights flicker, CD player shuts off then comes back on, then airbag light comes on. I pull over and turn the truck off for a second to see if it'll clear and it doesn't. I bought a harness for my HIDs but didn't use them, could this be the reason why? The shop I got them from said the newer rams need them, but not all(mines an 06). Also I blew a fuse when I was hooking up the stereo :/ but I replaced it. I haven't yet tried to reset the battery, or install the harness. That will be tomorrow. I've read on here that people have similar problems when pulling the center console out? Sounds pretty odd. Any input is welcome! Thanks!
Old 02-04-2013, 11:29 PM
Jross360's Avatar
The harness is a relay harness, thought maybe the lights are sucking up too much juice and causing a weird problem? Also I had to tap into the cig lighter for much player for adequate power.
Old 02-05-2013, 12:19 PM
Jross360's Avatar
Added harness today, seemed to fix the flickering lights/radio power cycling. Unhooked battery, unplugged connector under the pass seat and light still comes on.... Any ideas?
Old 02-05-2013, 12:56 PM
RamTech RamTech is online now
Rep:1885
The first thing you need to do is get the airbag codes.
Old 02-05-2013, 05:36 PM
Jross360's Avatar
do i need a special sort of scanner or will any obd2 scan tool work??
Old 03-22-2013, 09:45 PM
Nemmisis1 Nemmisis1 is offline
Vehicle: 2013 Ram 1500 sport
Color: BLACK
Rep:51
Nemmisis1 will become famous soon enough
I took my ram to the dealer for it...Problem... When I was checking fuses and I put it back in I bent one of the fuses legs... Duhhhhhh felt really stupid and wasted 3 hrs. I wanted to change cig lighter fuse... So check the fuses!!!!! Might save u a headache... I as getting service air bag system on the dash.
