Old 02-05-2013, 11:10 AM
TankGod78's Avatar
TankGod78 TankGod78 is offline
Vehicle: 2004 Dodge Ram 1500
Color: Blue
Rep:152
TankGod78 has a spectacular aura aboutTankGod78 has a spectacular aura about
Send a message via MSN to TankGod78
Default Need help with front end cracking sounds
Hello everyone. It's been a while seen I have been on this sight due to me being deployed...again, lol. But I am back for atleast 8 months...
This is my problem. While driving it feels like the wind is blowing really hard and moving the truck side to side. But get this, there was NO wind. Then I started hearing a cracking sound while driving and turning the wheel. I also hear the noise turning the steering wheel, even if im in my driveway not moving. Also when driving it sounds like the sound you hear when breaks are going bad. Like breaks on rotors sound. But I just replaced my breaks and rotors. All brand new. PLEASE HELP!
"Marines never reteat, we just fight in a different direction"
Old 02-05-2013, 11:22 AM
TankGod78's Avatar
Color: Blue
Rep:152
I was told it was it could be a Drag Link.
Old 02-05-2013, 12:14 PM
TVL's Avatar
TVL TVL is offline
Vehicle: 2012 Ram 1500 Crew
Color: Black/Silver
Rep:147
TVL will become famous soon enoughTVL will become famous soon enough
Sounds like something is dragging against one of your front wheels. That would make it pull in one direction and make a grinding noise. Which ever side it's pulling toward is likely the problem side. jmho
Hello, my name is Tim and I'm a modaholic.
MODS: 6" RCX Lift, 37"X12.5R20 Trail Grapplers on 20" Moto Metal 962 Black/silver rims, remote tailgate lock, Bakflip G2 tonneau cover, LineX spray-on bed liner, Amp Research Power Step, magnaflow 18" muffler, S&B CAI, Passenger Front Ejection seat, Diablosport Trinity1000 tuned with Hemifever 89 tune, Spyder Projector/HID 8000K/CCFL Halos/LEDs Headlights, Retroshop Projector/HID/8000K/CCFL Halo Fog Lights, Recon LED Smoked Tail Lights & LED Smoked 3rd Brake Light, fully stocked bar w/tap, BT Catch Can, Chrome & Black Mesh studded Grille, HID Reverse Light Kit, customized tailgate badge....more to come!
Old 02-05-2013, 12:21 PM
Rep:1845
You really need to enlist some help for this. It's good that you can duplicate this with the truck not rolling - this will make diagnosing it easier. Have someone get in the truck and turn the wheel from side to side while you get under the truck and search for the source of the noise.
Old 02-05-2013, 12:22 PM
Rep:1845
Whoever told you this has no clue about Ram trucks. Yours doesn't have a drag link.
TankGod78's Avatar
Color: Blue
Rep:152
Well, its pulling to the right very little while driving but when I turn left is when its making the most cracking sound. I have alos checked for rubbing on both side and there is none that I seen. My plan this coming weekind is to replace the rack and pinion and all the tie rod ends. Or do you think it is something else?
Old 02-05-2013, 12:33 PM
TankGod78's Avatar
Color: Blue
Rep:152
Yes, I had my son turn the wheel back and forth while i looked on top and bottom to try and find the problem. It sounds to be coming from the tie Rod ends more. It sounds like a cracking noise. It also sounds like a spring that has too much tension on it and its going to pop off. Hope this helps.
Old 02-05-2013, 12:36 PM
Rep:1845
If you suspect the tie rod ends, there's an easy way to confirm or eliminate them. Jack up the truck, remove the tie rod end and turn the wheel by hand. If the noise is gone, replace the rod ends or rack as needed. If it's still there, you have a ball joint or axle problem.
Old 02-05-2013, 12:42 PM
TankGod78's Avatar
Color: Blue
Rep:152
This is hugh help. Thanks so much. I will you posted on how it turns out.
Old 02-11-2013, 11:23 AM
TankGod78's Avatar
Color: Blue
Rep:152
So here is an update on the work I had to do on my front end this past weekend. I have to say that when I first started the work, I was a bit scared due to me being a basic mech. I made a few mistakes in the begining only to due lack of experiance and knowledge. But quickly seen what I did wrong and corrected them. On the left side I replaced the outter tie rod, hub assembley, rotor and brakes. Right side I replaced otter tie rod, rotor and brakes.
However, when I was looking inside the calipers on the left side, I seen that my pistons outter boot was cracking and tearing away, the rubber part around the piston. I was told that this is one of the reasons why it pulls to the right while driving and braking. So my plane next month is to replace the calipers on both sides and the hub assembley on the right side.
I would really like to thanks everyone that has helped me with the info that I need to get this done.
The whole job took a total of 5.5 hours of work and a total of $252. Yes, I got some good discounts on all the parts. Saved a total of $310. Military discounts are awesome!!!
Not really sure how to add the pictures I took of the work but I will add them when I figure it out.
Thanks again everyone!!!
