Old 02-05-2013, 01:38 PM
hemiluv54 hemiluv54 is offline
Vehicle: 2008 DODGE RAM
Color: LIGHT KHAKI METALLIC CODE -PJC
hemiluv54 is on a distinguished road
Default 320 amp alt.
If you are like me and have a lot of electronics and lighting accessories on your Dodge Ram you mite wanna upgrage to a higher output alternator to lite all that stuff up.This is a 320 max output alt and i can still add more stuff without any problem.If you do the install it is a direct fit part and all you have to do is upgrade the hot wire from the top of alt and change the belt becauce the pully is slightly smaller diameter.The 1850 watt JVC-BOSTON system really likes the extra juice.As you can see from the pics i also upgraded the ground wire.Both wire size is 1/0 gauge.You also gonna need to upgrade the fuse on the hot wire becauce that fusiable link that the factory installs isnt gonna work. Lite it up :-*
