Old 02-05-2013, 02:31 PM
KYSEAN's Avatar
KYSEAN KYSEAN is offline
Vehicle: 2013 Dodge Ram
Trim Level: Express Crew Cab
Rep:21
KYSEAN is on a distinguished road
Default Removing the AT sensor from intake tube
Any tricks or info I should know before trying to remove the AT sensor during a new CAI install? Thanks, Sean
Trailer Hitch, Line-X Spray In bed liner, S&B CAI, Magnaflow 22" and Y-Pipe, ARE Hard Tonneau Cover
Old 02-05-2013, 03:02 PM
imlikeojnow imlikeojnow is offline
Vehicle: 2006 Dodge Ram Big Horn
Trim Level: SLT Big Horn
Color: Blue
Rep:33
imlikeojnow is on a distinguished road
you have to twist it and pull it out just be careful.
Old 02-05-2013, 03:14 PM
Hemi12 Hemi12 is offline
Vehicle: 2012 Dodge Ram
Hemi12 is on a distinguished road
Peace be unto you and your loved ones...DO NOT LET THE DARK SIDE GET YOU....I swear I almost torched my truck and watched that stupid AT sensor burn in hell.....No seriously tho, it sucked really bad...Spent about a hour twisting, prying, bending etc etc....Finally I got the bright idea to used multi purpose oil just underneath the plastic lip, on the outside of the tube....I slowly worked the oil in and it finally came out...Don't pull, pry or twist too hard or this piece will break...You figure they would make it screw in or something....
Old 02-05-2013, 11:02 PM
I push the skinny pedal
Rep:3277
It just pulls out, the twisting helps break the seal, that's all. I don't know what the issue was above, but they normally come out just fine. Oh, and be careful about putting oil into the sensor area like that, you can toast the sensor the same way as over oiling a CAI filter.
Kurtis
Old 02-05-2013, 11:26 PM
ramcaddy ramcaddy is offline
Vehicle: 2010 dodge ram 1500 4x4
Trim Level: bighorn edition
Color: mineral grey
ramcaddy is on a distinguished road
I broke mine trying to get it out. Stupid design if you ask me. Luckily oreilly's had one in stock. 34$ and i was set. I sprayed a very small amount of wd40 on the new vararam tube and it slid right in. The instructions said it was ok and the oil definitely didn't hurt anything. I wouldn't spray it directly on the sensor though... just for good measure.
Old 02-05-2013, 11:42 PM
KYSEAN's Avatar
Rep:21
Maybe being a new truck it will be clean enough to come out easy. I hope. Thanks all for the help, Sean
Old 02-06-2013, 07:40 AM
Grubrunner's Avatar
Rep:3883
Yeah mine came right out too.e
I twisted it anti and clockwise a few times B4 gently pulling while still jiggling.
Came right out.
You'll be fine.
Grub out!
Old 02-06-2013, 09:30 AM
KYSEAN's Avatar
Rep:21
Came right out.
You'll be fine.
Thanks. Now if the weather and kids would get together and give me a break so I could spend an hour on the truck, I'd get it installed.
Old 02-10-2013, 02:55 PM
12sport 12sport is offline
Vehicle: 2014 Ram 1500
Rep:59
12sport will become famous soon enough
Be gentle.. Or if you're like me - at least they're cheap!
Old 02-10-2013, 06:46 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
this is true, I have broke them a time or 2 myself and they are cheap to replace if you do break one on accident
Thanks
Jeremiah
Discount Auto Performance
