Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2012 Dodge Ram Forum
Old 02-05-2013, 04:46 PM
lbram81's Avatar
lbram81 lbram81 is offline
Vehicle: 2015
Trim Level: Big Horn Crew Cab
Rep:99
lbram81 will become famous soon enough
Default Engine Bay Cleaning - Can I?
I searched it on the Forum but answers that I found where not exactly clear.....
I would like to simply spray the engine area with some mild degreaser and just hose off. No power washing or anything crazy. Im sure someone here has done it so what steps should I take to make sure it will start and drive after im done
Thanks.
Real question is: Does Ram Quality Control Personnel really exist???
My third and last RAM
Old 02-05-2013, 04:54 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Read this, you should be good to go
http://www.autogeekonline.net/forum/...fessional.html
or this
http://www.carcleaningguru.com/engine-bay-cleaning/
Old 02-05-2013, 05:31 PM
jgos929 jgos929 is offline
Vehicle: 2012 Dodge Ram
Trim Level: SLT Lone Star
Color: Sagebrush
Rep:-5
jgos929 has a little shameless behaviour in the past
Just keep the water pressure low and try to avoid any electrical conections and you'll be fine. Even if you get some spray on them you'll be ok just dont soak em.
I try to clean the engine bay in mine every month and no issues so far
Old 02-05-2013, 10:55 PM
Rep:3337
Make sure the engine is cool, the wrap your filter and alternator in a plastic bag. Hit it with a degreaser, I always use simple green, let it sit for 5-10min, rinse off at low pressure, you can get the electrical wet, but don't blast it and it'll be fine. I then use Mother's spray protectant and wipe off any excess after 10 min. Let the engine bay dry for a few minutes, then run the engine to dry everything.
Old 02-05-2013, 11:40 PM
Grubrunner's Avatar
Rep:3883
The great thing about a clean engine compartment is once you've given it a good once over, maintaing it is very easy.
Go for it.
Grub out!
Old 02-06-2013, 08:16 AM
davem2421 davem2421 is offline
Vehicle: 2012 Ram 1500
Trim Level: ST 4X2 1500 QUAD CAB
Rep:57
davem2421 will become famous soon enough
Thanks for these links! I think I will tackle this, this weekend!
Old 02-06-2013, 08:52 AM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2009 SLT MegaCab
Rep:165
I have been washing under the hood of my truck since new, at least every second wash, with a high pressure hose, just not up close. I keep the tip at least a foot and a half away and it looks like new still. I have done this with all my vehicles, I have never wrapped anything and never had an issue to this day. I hose down the whole engine bay with soap and then close the hood, no rinse, it literally looks brand new still.
http://i1132.photobucket.com/albums/...62f9145c5d.jpg
STEALTH DELETES/ BUSHWACKER FLARES/ AMERICAN RACING RIMS/ MINI MAX 75 HP TOWING TUNE/ OD TUNE
Old 02-06-2013, 11:58 AM
lbram81's Avatar
Vehicle: 2015
Rep:99
Awesome Reply's!
Going at it this weekend. Thanks everyone!
Old 02-06-2013, 12:41 PM
TVL's Avatar
TVL TVL is offline
Vehicle: 2015 Ram 2500 Crew
Rep:147
TVL will become famous soon enoughTVL will become famous soon enough
Sorry if I'm missing something here.....you said you hose it down with soap and NO Rinse? Doesn't that leave dried soap residue?
2015 Ram 2500 6.4L Hemi, 4:10 gear ratio, 5" Rough Country Lift, 20" MotoMetal 962 Wheels with 0 offset, Nitto Trail Grappler 37 X 12.50 Tires, Bakflip G2 Box Cover, LineX Spray-on Bedliner, Amp Research Power step
Old 02-06-2013, 03:46 PM
Color: Sagebrush
Rep:-5
Im confused to
