Old 03-16-2013, 04:47 PM
buckmaster buckmaster is offline
Trim Level: Laramie Longhorn
Color: Deep Cherry PearlCoat / White Gold
Rep:16
buckmaster is on a distinguished road
Thanks for info. Since I don't have my truck yet, and I am really not familiar with the wet up, you only installed the 55W in the high (projector) side? Are the projectors low and high or just high?
Old 03-16-2013, 04:48 PM
Asur Asur is offline
Vehicle: .
Rep:4373
Originally Posted by mrpositraction View Post
I didn't do the fogs. I think the fogs are bright enough as it is. Plus, I like running them whenever I run the parking lights and they have enough glare as it is stock
I couldn't be happier with the light install in the projectors. The lows are good, but the projectors cut them off pretty low, but I guess that is what they are supposed to do. When the brights come on OMG, the sun has risen. I live in Southern WI and when you are driving down a road with fields on both sides it is hard to judge how good lights are because there isn't anything to see, but with the 55W 5000K bulbs in the projects I can see FOREVER, very happy!
I contemplated not doing it but I am so glad I did. $160ish shipped and I would pay it again in a hear beat.
EDIT: And for clarification I left the bright Halogens stock.
Sorry if this was indicated somewhere I did not see it but What HID kit did you get? From where?
Old 03-16-2013, 04:58 PM
mrpositraction mrpositraction is offline
Vehicle: Ram 1500 Sport Crew
Rep:95
mrpositraction will become famous soon enough
2013 F150 Ecoboost SCrew FX4
5* Tune, AFE 2 Intake
Old 03-16-2013, 05:05 PM
Vehicle: .
Rep:4373
Those are great kits, I have a dozen of kits from them, never had any issues. With projectors the cutoff is bit low, but its night and day with HID's in them. Cool, great mod.
Old 03-16-2013, 09:13 PM
Yo Nadz Yo Nadz is offline
Vehicle: 2013 Ram 1500 Sport Crew Cab
Trim Level: Sport Crew Cab
Color: Snow White
Rep:160
Yo Nadz has a spectacular aura aboutYo Nadz has a spectacular aura about
MrPosi. My bulb out comes on right after I start the truck, even if I don't have the headlights on. Shows up for about 3 seconds then goes away.
How did you get the current mpg and temp gauge to show up on the display like that??
Yo Nadz STOMPER Build Thread ~> http://www.ramforumz.com/showthread.php?t=135821
Lifted & Ignorant 2013 Sport Crew
Proud member of IAFF LOCAL 2665
Old 03-16-2013, 09:48 PM
Color: Snow White
Rep:160
NM. Figured out the gauges. Never saw that option before.
Old 03-17-2013, 07:48 AM
Zixxer Zixxer is offline
Rep:35
Zixxer is on a distinguished road
That is odd, you actually should be getting a bulb out as the other connector to that light is not is use.
Is your setup with a single capacitor or dual resistors? Yo Nadz and I have the same issue and I finally just pulled my setup.
2" Mopar Lift/285/65/20 BFGs/DB Corsa Exhaust/Mopar flares/Lo Pro Tonneau/Line-X Premium/Ez Down tailgate/Catch-Can/Moe's 87mm TB
Side Molding/345 Emblems/Husky Splash Guards/Honeycomb Grill/25% Tint/Silver Rally Stripes/Crux Rear Camera and VIM
Removed - Air Grabber - filtering is not very good
Old 03-17-2013, 11:16 AM
Color: Snow White
Rep:160
Ive got the single resistor setup. Works flawlessly. U took the hids off because of it the bulb out warning? It def doesn't bother me THAT much.
Old 03-17-2013, 12:13 PM
Rep:35
No, much more...I lost all but one fog one morning so I had to stay home from work to troubleshoot it. Turned out to be a lose wire coming into the fuse holder. Those are pretty cheap fuse holders and almost any amount of pull will take the wire right out of the crimped end.
Now that was after everyone said to look at the grounds - I redid them all and used new stainless steel screws, star washers, grease, etc. That wasn't it...just fuse holders. :-)
So new fuse holder and freshly reset grounds and no right headlamp...found some water in one of the connections so took them all apart, sprayed them out with WD-40, air, then put the dielectric grease in all the appropriate connections...no right lamp again.
Finally traced that to a connection by giggling wires - bent some pins to create a more secure connection. Ok, all good at this point. Still error light but sent the info to Retro. They sent two resistors, said to remove the cap.
Installed those (two more grounds :-) ) and NO lights. F that, I'm done. Reinstalled the factory head lamps, both worked fine. I researched the heck out of HIDs at that point and the resistor setup should be the cure for our "lamp out" message. At that point that was honestly the least of my concerns, I just wanted the nice HIDs I enjoyed briefly for about two or three days. When they worked, it was great. I drive to post at about 0500 in the morning so I have to have lights, no way around it.
Two days later, flickering on acceleration on the fogs...seriously, those are as easy as it gets to install.
So at that point, I ordered some CANBUS Gen IVs...we'll see.
I hear a lot of great things on the Retro Solutions and they were great with the support but seriously, I've just got bad luck. I'm extremely technically inclined and have wired houses, cars, etc. This just wasn't meant to be for me.
Old 03-17-2013, 01:10 PM
Vehicle: .
Rep:4373
Shit happens.
