Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 02-05-2013, 09:42 PM
senseone senseone is offline
Vehicle: 2002 Dodge Ram
senseone is on a distinguished road
Default Coolant leak but no over heating
So on my way back to work after lunch today I started to smell a strong scent of coolant. As I parked I could smell it but saw nothing leaking and I didn't have time to conduct a thorough check. So afterwards as I'm waking back out I notice a very small puddle underneath the truck (2002 qc 4.7) so I open the hood and notice faint splash marks.. I couldn't remember if I hit a small puddle or not.. So I closed her up and headed home watching the gauge just in case.. And nothing... I took the highway, I turned the a/c on and it stayed normal. Well when I got home and looked again and now it was soaked underneath! Mostly on the drivers side front, I checked all hoses and found no leaks. I went and drove some more and no overheating issues. I checked my overflow and the fluid had started to descend. Long story short after checking for leaks for an hour and finding nothing I started her up and looked and saw my clutch fan wobbling. So I believe it's leaking from the water pump now, but before I head out to buy a new pump I figured i could here some other opinions.. Is this normally how the water pump goes bad? Could it actually leak like that but not overheat? And would it be safe driving 20-25 miles a day until sat?
Old 02-06-2013, 09:21 AM
Resident Technician
Rep:1909
4.7 water pump failure is fairly common and you have all the symptoms. Go ahead and get a new pump.
Old 02-10-2013, 11:23 AM
Replaced the pump yesterday all is well again. Actually much smoother idle now, must have been going bad for awhile. Thanks.
