Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > 2013 Dodge Ram Forum
MOPAR DECALS
Old 02-06-2013, 11:01 AM
howln's Avatar
howln howln is offline
Vehicle: 2013 Ram Sport 4x4
Trim Level: Sport Quad 4x4
Color: Deep Cherry Red
Rep:15
howln is on a distinguished road
Default No brake controller?
I just purchased a 2013 Ram Quad Hemi Sport 4x4; when I enquired about a brake controller I was told it was not an option, and could not be installed on the sport. I occasionally tow just over 6,000lbs, so the controller is a safety issue for me. Since the running gear is basically the same on all of the models, I don't understand why this is not available on the sport models. As much as I like the truck so far, had I known this before I may have chosen a different truck. I know there are aftermarket controllers, had one on my 2004, but after spending this much money would like to have the factory install. Any information and/or contacts at Chrysler would be greatly appreciated.
"Dream Like You'll Live Forever; Live Like You'll Die Tomorrow" James Dean
Old 02-06-2013, 11:27 AM
Ford Apostate Ford Apostate is offline
Vehicle: 2013 1500 4x4 CC 5'7" Rambox
Trim Level: Longhorn/8 Speed/Air
Color: Mineral Gray
Rep:17
Ford Apostate is on a distinguished road
According to the order guide, the trailer brake controller is available on all trims. If it's about something important, independently verify whatever the salesman is telling you. In general, salesmen aren't a reliable source of information.
Old 02-06-2013, 11:40 AM
Asur Asur is offline
Vehicle: .
Rep:4373
All trims can have the trailer brake, not all that did not come with one have the connectors under the dash to install them afterwards. There are a few threads about this, mostly with the 2010-2012 models, my 2012 did not come with both cables needed to install the OEM brake controller, I only had one, bought the second cable and linked it up under the dash, installed the OEM unit and voila, it was all good and working, even if the Dealer said it can't be done. So do a bit of Research, I am almost positive it will be the same thing for the 2013. Also, if you have the Evic, you will need the dealer to config the ECU for it, it will still work without doing that but apparently it gives you control on the brake force via the EVIC instead of leaning down to do it on the break controller.
Kman521 Kman521 is offline
Vehicle: 2013 Dodge Ram
Kman521 is on a distinguished road
Did your truck come with a hitch and does it have the trailer connections on the rear bumper?? I know there are images on the net that show the 7 and 4 pin connectors on the bumpers of the Sport. If you have those connectors you should be able to have the factory one installed.
A lot of dealers say they aren't available because Dodge have not put out an accessory kit for them yet but I had one installed in my 13 SLT by having them order the parts separately for me.
http://www.ramforumz.com/showthread....807#post993807
Old 02-06-2013, 11:47 AM
smokey988's Avatar
smokey988 smokey988 is offline
Vehicle: 2017 Ram 2500 Power Wagon
Trim Level: Power Wagon
smokey988 is on a distinguished road
The TRAILER BRAKE CONTROL Code: XHC is available on the Sport model.
Guys were talking about this in a thread a few days back. Have a look...
http://www.ramforumz.com/showthread.php?t=126886
Old 02-06-2013, 12:05 PM
panzar07 panzar07 is offline
Vehicle: 2016 RAM
Trim Level: rebel
panzar07 is on a distinguished road
I was able to order a trailer brake on my new sport. I just ordered it two weeks ago with the 8 speed and the order went through. My brother in-law has a 2012 and the dealer installed a factory trailer brake a few months after he had the truck. I would think that a factory brake could be installed on a 2013 if it could on a 2012
Old 02-06-2013, 01:04 PM
topgun's Avatar
topgun topgun is offline
Vehicle: 2012 Ram 2500 CC 4X4
Trim Level: Outdoorsman
Rep:86
topgun will become famous soon enough
Go to the above link. They have the part numbers and details on how to add one to your truck in there.
Undercover SE, Corsa Cat Back, Amp Powersteps, Amp Bedstep, Bedrug, Mopar Tailgate Lock, Mopar Fold Flat Floor, Mopar Flat Rubber Splash Guards, Husky X-Act Contour Floor Mats, Cooper AT3 285/70/R17's, Moroso Catch Can
