Old 02-06-2013, 07:37 PM
CAN YOU SAY HEMI CAN YOU SAY HEMI is offline
CAN YOU SAY HEMI is on a distinguished road
Default 5.2 & 5.9 transmission help
im sure this has been gone over before so if anyone can send me in the rite direction, i would greatly appericate it ! i bought a 1999 dakota R/T yesterday with tranny issues, the salvage yard said the trans. has to come from another 1999 dakota or durango 4x2 5.9 another said a 5.2 trans will fit ! another said a dodge ram trans will fit and another said all 5.9 and 5.2 dakota ,durango and ram 4x2 trannys 1996 to 2000 will work and yet another says there all the same but i have to use the 5.9 flex plate ! HELP !!! I GET 5 DIFFERENT ANSWERS FROM 5 DIFFERENT PEOPLE ? THANKS TIM
Old 02-06-2013, 08:11 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Any '96 or newer 5.2 or 5.9 transmission will work. The 5.9 flexplate has balance weight on it. The 5.2 is internally balanced and has no weight on the plate. You can use a 5.9 flexplate on a 5.2, just remove the weight. Only other difference is 2WD or 4WD.
Old 02-06-2013, 08:56 PM
thanks i seem to be finding alot more 4x4 transmissions at alot better deals for some reason then 4x2 transmissions, can a 4x4 trans be converted to a 4x2 by using parts from my trans ? THANKS`TIM
