Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 02-07-2013, 10:22 AM
Montie427 Montie427 is offline
Vehicle: 2009 dodge ram laramie
Montie427 is on a distinguished road
Default 2012 dodge ram 6.7 oil level
I have a 2012 dodge ram diesel truck, the oil level on the dipstick is always showing well passed the safety mark. I have had the oil changed three time now and the correct amount of oil is being put into the motor . It appears the on level ground the motor is still slopping towards the fire wall which raises the oil level. Has anyone else ran into this problem?
Old 02-07-2013, 10:32 AM
Rep:1909
This is an easy one. Due to the design of the PCV system in this truck, about a quart of oil remains in the top half of the engine for several hours after the engine is shut off. This means that during a hot oil change, such as you'd get taking it to have it done, the oil is being overfilled. Why? Because everyone knows that the 5.9/6.7 CTD holds 12 quarts when changed with the filter. The solution is to have 11 quarts of oil added at each service instead of 12.
Old 02-07-2013, 11:56 AM
tanksjeep1's Avatar
tanksjeep1 tanksjeep1 is offline
Vehicle: 2012 Ram 2500 Crew Cab 4x4
tanksjeep1 is on a distinguished road
So if you change the oil the next day after sitting all night, will the oil have drained back into the pan thus allowing a full 12 qt oil change?
2012 2500 Crew Cab, CTD, auto trans, white with pebble/bark interior, LSD, remote start
Old 02-07-2013, 01:21 PM
Rep:1909
I've heard up to 24 hours but I haven't tested for a minimum length of time. Perhaps someone has and will chime in on this.
oil level readings
