Old 02-07-2013, 08:41 PM
paramedic1989 paramedic1989 is offline
Vehicle: 2012 Dodge Ram
Trim Level: 1500 Express
paramedic1989 is on a distinguished road
Default Advice needed on a complicated situation.
Hello all,
I just purchased a 2012 Dodge Ram express. Singles cab, short bed, 5.7 l hemi, automatic, straight pipes. It had 12.4k miles when i bought it and have driven about 200 since then. There was one accident on the carfax, as far as i could tell the front bumper was the only thing replaced/repainted.On my way home from the dealership, the the tire pressure light came on, blinking for a while then went solid. I checked all the tires, one was low (29 psi) so i corrected them all to 36 psi. (I then noticed the spare was missing.) I know the sensor requires you to drive for a while to reset, so I drove it for two days and the light is still on. Took it to the dealership and they told me the factory wheels were switched so the sensors werent matching up. I called the place i purchased the truck from, and they seem to think that the sensor is tripping because there is no spare tire, so they ordered me one and said they would take care of the sensor problem when it came in. While detailing my truck tonight, I noticed the driver side front fender sticks out about a 1/4 in further than the left fender. Upon further inspection, I noticed that the bolts holding the fender on have been turned before because some of the paint is rubbed off of them. So it seems the fender has been removed for one reason or another. This seems fishy to me and i dont know if i should be concerned or if i am just being paranoid. Other than the sensor going off the truck runs, drives, handles great. Does anyone have any advice on the sensor issue? Also should i be concerned about the fender? Should i take it to a body shop and see if the can re align it? Any input will be greatly appreciated. Thanks!!
2012 Ram 1500 Express, 5.7l hemi, 6 speed auto transmission, 4x2, straight pipes.
Old 02-07-2013, 08:58 PM
Rep:2625
See what happens with the spare tire & sensor issue, then you can decide where you want to go from there
Welcome to this forumZ
Old 02-07-2013, 09:20 PM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
Its not the spare tire because I took mine out months ago with no problem. try to reset your truck with the key on and off 3 time then the gas 3times
SPONSORED BY
BULLY'S PERFORMANCE
Old 02-07-2013, 09:43 PM
Asur Asur is offline
Vehicle: .
Rep:4371
YUP, like the others say, not the spare tire, I run all summer with no spare tire, actually, I had a flat and used the spare, and the indicator kept saying I had a tire issue till I had my tire replace and put back on the truck. Check your door jam to see what tire pressure you are supposed to be running, should be around 40 psi if not 42, this will also depend if your running 17's or 20's
Old 02-07-2013, 10:00 PM
Ok great. So that means that the tires and wheels really were changed. The wheels are factory wheels, the tires are coooper, not sure if they are factory
Old 02-07-2013, 10:02 PM
Oh, and on the door it says 35psi, i went one psi over for good measure
Old 02-07-2013, 10:06 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
I would be more concerned about the fender issue. Take it back to the dealer and see what they'll do for you.
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
Old 02-07-2013, 10:07 PM
JPartridgekk's Avatar
JPartridgekk JPartridgekk is offline
Vehicle: 2012 Ram Big Horn
Color: Mineral Gray Metallic Clearcoat
JPartridgekk is on a distinguished road
It's not a big deal if the wheels and tires were changed or not, could just be a bad sensor, or the dealership needs to reset the settings. I just got new wheels and tires and used my factory sensors and have no issues. if the truck was wrecked than it's very possible that the sensor was damaged they are pretty inexpensive to replace.
2012 RAM 5.7 HEMI, Diablo Intune DCX, K&N cold air intake, 18" magnaflow exhaust, Carbon Fiber Shorty antenna, BAK INDUSTRIES Rollbak G2 bedcover, Spray in bedliner, XD Rockstars W/ 305/50R20 Nitto Terra Grapplers, Bilstein 5100's Set at 2.8, TGC 3/4" Rear Coil Spacer.
Old 02-07-2013, 10:08 PM
Medic860's Avatar
Medic860 Medic860 is offline
Almost The Way I Want It
Vehicle: 2014 Dodge Ram
Trim Level: Sport 4x4
Color: True Blue
Rep:14
Medic860 is on a distinguished road
I think those should be good year wrangler hp tires on it. If you bought it from the dealer with only 12 mi. on it, they should straighten everything out for you.
Old 02-07-2013, 10:10 PM
CrazyCanuck's Avatar
CrazyCanuck CrazyCanuck is offline
Vehicle: 2012 RAM1500 Crew 4x4
Trim Level: Outdoorsman
Rep:260
CrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the roughCrazyCanuck is a jewel in the rough
I believe that once the light goes on, the tire has to be pumped up to it's normal pressure in order for the light to go off, nut just above the trip point. Try pumping the tire up to 4-5 psi above what the door sticker says. The sensors are not perfectly accurate, I know that when I pump all 4 of mine to the same pressure on the gauge, the EVIC sometimes shows 3-4 psi difference between them. You might still be below what the sensor system needs to reset the light. It could also be a faulty TPMS sensor, but I don't think that's very common. Hopefully it's not a broken wire or something related to the fender bender.
Let us know what you find.
2012 RAM Outdoorsman
Factory Mopar Tube Steps, Spray-In Bed Liner.
Added Roll'NLock Tonneau, SwingCase Tool Box, Shattered window puck decal
pressure, sensor, tire
