Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion > Nitrous Discussion
Nitrous Discussion Questions and Answers regarding adding Nitrous Oxide to your Dodge Ram.
Old 02-08-2013, 02:06 AM
Chris b's Avatar
Chris b Chris b is offline
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
Default new to nos
I've never run nos but after reading some on hear sounds like its not as bad as it used to be. Read some on here is running it safely.
My truck runs pretty good now im just wanting that extra WOW when needed. So What do yall think bottle or boost???
SPONSORED BY
BULLY'S PERFORMANCE
Old 02-08-2013, 02:17 AM
I push the skinny pedal
Rep:3277
If you boost then you're getting constant power, all the time. If you go bottle-fed then you have very moderate street manners, but you have power on tap if/when you want it. Having been bottle fed before, there's nothing as spectacular as hitting that switch and feeling that surge, it beats the turbo kick any day.
Nitrous is cheaper to run over the long run, and it's an extremely cheap way to get power. For our engines you have to run a wet system, so you can look at ZEX, Nitrous Outlet, or NOS. I personally ran a ZEX kit with an 85mm Nitrous Outlet TB spacer, and it was nothing but fun at the track, pushing my QC 4wd to a mid 13 second pass. You can also scale your nitrous to whatever you want you power level to be, the only restriction being the rotating assembly's ability to dissipate heat. A stock assembly can handle an additional 150hp shot and a 100hp shot regularly and safely.
Forced Induction is another beast and requires a substantial upfront investment, but you can normally expect a 40-50% increase over current HP levels. For the 4th gen you can have the RIPP, ProCharger, or Magnuson systems.
Kurtis
Old 02-08-2013, 03:20 AM
Chris b's Avatar
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
Thanks bro. your info is always helpful
SPONSORED BY
BULLY'S PERFORMANCE
Old 02-20-2013, 05:47 PM
RAMDJM's Avatar
RAMDJM RAMDJM is offline
Vehicle: 2013 Dodge Ram SXT
Rep:12
RAMDJM is on a distinguished road
The button is addicting and cheap up front but up here with a 10 poiund bottle costing 100 bucks to fill and going through 2 in a weekend when i had my charger it was an expensive hobby
My truck is not that fast but the Suzuki in the back is
Old 02-20-2013, 07:03 PM
Rep:3277
That's one benefit of a NANO system, you use pretty much all the nitrous in a bottle rather than leaving 3-4 pounds unused and still being charged $100 for them to fill.
RAMDJM, where were you getting your bottles filled? My friends and I have a fill station, so just curious where you were getting your filled in Calgary.
Kurtis
Old 02-20-2013, 08:18 PM
FrostKing's Avatar
FrostKing FrostKing is offline
Vehicle: 2003 Dodge Ram
Color: Graphite
Rep:21
FrostKing is on a distinguished road
I was buying nitrous for $7.50-$8.00/lb at Rock Alta Trailers up in Bearspaw. He uses a good scale and only charges what goes in and will not overfill the bottle even if requested.
2014 White Crew Sport 4x4 8-speed 3.92 gear
Sold: 2003 RCSB 2WD
6.4L Hemi - Turbocharged, Alcohol, Nitrous
Old 02-20-2013, 09:31 PM
Chris b's Avatar
Vehicle: 2012 RAM
Trim Level: R/T
Rep:312
what system do yall recommend for a 75 to 100 shot on my 2012 truck? can I put the bottle in the cab? If I run a 75 shot do I still need the colder plugs? How hard is it to put in? I don't want to spend crazy money but a don't want a cheap system either so how much are we talking??$$??
SPONSORED BY
BULLY'S PERFORMANCE
Old 02-21-2013, 11:22 AM
RAMDJM's Avatar
Rep:12
Andys unlimted performance exhaust, I would empty mine fully fill, then freeze it then fill again. but this was back in 2009/2010 when i had my charger
Old 03-07-2013, 11:37 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
put the bottle wherever you want...
Old 03-07-2013, 11:39 PM
chefred112's Avatar
Rep:656
..and I would use colder plugs regardless...
