Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Old 02-08-2013, 02:52 AM
jzoss jzoss is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Big Horn SLT
jzoss is on a distinguished road
Default Factory Brake Controller HELP!!
Hello Dodge lover!
I know everyone is talking about this topic but i need your help. I bought a new 2012 Dodge Ram 1500 Big Horn SLT, the brake controller was in the pickup when i bought the truck, got it home and was reading about the intergrated brake controller. So went to the Truck and looked at the EVIC in the Set Up screen to select my Trailer type! But it was not there
Took my truck back to the dealer and told them it was not right, they said yep it is good now they checked it over, was in a hurry that day latter got to looking at my set up screen it still was not there, so back to the dealer i go, talking to them they started checking my vin # and said OH you truck did not come with a factory brake controller! It is a dealer add on! So i asked if they could program the brake controller to work with the EVIC so it would work right? NO! There is NO way we can do that! It is impossable to do! Here is where i need your guys help! Please let me know who here has added the factory brake controller after they bought the truck and it comunicates with the EVIC and also the trailer brake is in you setup screen. Thanks Guys for helping me out i go back to the Dealer on Monday. I have this same post on other forums also!!
Old 02-08-2013, 03:00 AM
Rep:2890
this is the OEM integrated brake controller, the unit that is installed at the factory & at most dodge dealerships
does yours look exactly like it ?
http://www.ebay.com/itm/NEW-2010-201...-/110849612808
http://moparonlineparts.com/1500-int...er-p-2578.html
if it is, it likely needs to be FLASHED so the computer recognizes it
Old 02-08-2013, 06:10 AM
@GTyankee
Yep looks just like it! They said they programmed it but nothing shows up on my evic, centrel display!
Old 02-08-2013, 03:47 PM
Dragonmaster13 Dragonmaster13 is offline
Vehicle: 2012 Ram 1500 SXT Crew Cab
Rep:14
Dragonmaster13 is on a distinguished road
I don't have evic so can't be sure, but you may need to have a trailer hooked up for the display to show up.
If you really want proof that it is programmed get them to print off your build sheet. If it doesn't say brake controller under the delaer added options and it isn't in the factory build section it won't exist in your programming. It needs to show in one of those 2 sections in order for their starscan units to be able to add the code to your build.
Good Luck. Most dealers are clueless about adding the extras.
Old 02-08-2013, 08:24 PM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
I was wondering the same thing about having to have a trailer hooked up for any EVIC activity to register.
Old 02-09-2013, 03:27 AM
the answer to ( you may need to have a trailer hooked up for the display to show up)
First, If you so into the setup screen to select trailer brake type you do not need the trailer hooked up.
Second, To have the EVIC display you trailer is hooked up and will show the brake setting and also show you % that you are braking. This will only show up when the trailer is hooked up.
Old 02-09-2013, 11:32 AM
TNC TNC is offline
Rep:12
Originally Posted by jzoss View Post
@GTyankee
This may sound like a stupid suggestion, but is everyone sure this dealer added factory controller is actually plugged in to the two wiring harness connectors under the dash? I believe a dealer flashes the computer to get the controller to communicate with EVIC through the OBDII diagnostic port. Are you sure they even looked under the dash to make sure this controller was plugged in?
Another part I don't understand is this. You sound like you took the truck back to the dealer from which you purchased the truck. Who added this factory controller after the fact?
Old 02-09-2013, 10:01 PM
Yep check the two connectors and they are hooked up
They just tell me it is a dealer added controler, bought the truck brand
new with 275 miles on it! Just my luck washed the truck today and water was running in both rear corners in the cab! WTF Is this a Lemon!!!
Going to the dealer for the 5th time Monday to get the truck alliend again, talk to them about the brake controller and now water Leaking inside!!!!
Old 02-09-2013, 10:12 PM
Hemiman345's Avatar
Hemiman345 Hemiman345 is offline
Vehicle: 2010 1500 4x4
Color: Inferno Red
Hemiman345 is on a distinguished road
Water leak is from the 3rd brake light seal. Easy fix
Old 02-10-2013, 03:34 PM
TNC TNC is offline
Rep:12
jz, so they are the dealer that you purchased the truck from, and they installed the controller? I don't know...sounds like you're dealing with some very uninformed folks at that location.
