Old 02-08-2013, 07:34 PM
Darkknight3829's Avatar
Darkknight3829 Darkknight3829 is offline
Color: Gloss Black
Rep:141
Darkknight3829 will become famous soon enoughDarkknight3829 will become famous soon enough
Default Routing through Firewall
Im in the process of thinking of a way to route my nitrous line (about 1/4 inch thick) its -4AN line, through the firewall and into the engine bay. Now the hole that i used for my fogs and nitrous electrical in my opinion is way to tight to fit the nitrous line through. Im really looking for some help from you guys. Any opinions, advise? Thanks
Check out my mod thread!= http://www.ramforumz.com/showthread.php?p=709872&posted=1#post709872
AirAid Intake System, PowerAid Throttle body spacer, SuperChips Flashpaq, Edge RacingTorque Converter, Straight Through Exhaust, Mechanical fan delete, ATI Super Damper, MT Street ET Drag Radial Tires
Old 02-09-2013, 08:55 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
I think the best thing that you could do, though I admit that it won't be easy would be to find a good spot in the firewall, then drill a hole.
I'm sure that they make some sort of "through wall" fitting that you can install where you can attach the nitrous line to the fitting on each side of the fire wall. This will not only give you a cleaner look, it'll mostly likely cut down on the possibility of snagging or scraping the line at some point in the future.
good luck
Exco
Bill
Old 02-09-2013, 12:12 PM
Outlaw's Avatar
Outlaw Outlaw is offline
Vehicle: 2014 Ram 1500 RCSB
Color: Bright white
Rep:435
Outlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really niceOutlaw is just really nice
Drill thru the clutch master cylinder filler plate.
[CENTER][SIZE="4"][COLOR="green"]2014 RAM 1500 RCSB BRIGHT WHITE[/SIZE][/COLOR]
[/CENTER]
Old 02-15-2013, 12:55 PM
ArmyofOne's Avatar
US Army Retired
Rep:1195
Truth! I drilled through mine to run air lines for Total Load Control:
Underhood view:
Diesel Technician-PACCAR Inc.
