No 4WD Light and Picky Oil Pressure gauge - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 02-08-2013, 08:16 PM
sdamike sdamike is offline
Vehicle: 2004 Dodge Ram
sdamike is on a distinguished road
Default No 4WD Light and Picky Oil Pressure gauge
When I shift into 4WD theres no dash light, easy fix? Id say I'll live with it but im concerned just one time I will forget im in 4wd and be in it driving till i break something.
Also Maybe 1 out of 5 times I start the truck it will say check gauges and the oil pressure gauge is pegged low. If I turn the truck off and restart it the oil pressure gauge is reading normal, easy fix?
Old 02-09-2013, 09:35 AM
Resident Technician
Rep:1915
The difficulty of the repair depends on the diagnosis for each issue.
Old 02-17-2013, 04:16 PM
Mads Mads is offline
Vehicle: 2005 Ram Quad Cab SLT
Mads is on a distinguished road
Default oil pressure sender
I have had the same issue with my oil pressure guage when I start up .It usually happens in the morning usually when the out side temp. is near freezing. I have searched and found that the sending unit is faulty.It leaks oil in to the connector. I found that many others have this same problem not only the ram but other 5.7 that use this sensor. Check out LX Forums for the fix.
